Results 1 to 5 of 5
Thread: cutting end grain
    Decatur, Illinois
    177
    cutting end grain
    ok, earlier i said i am new to turning and just set up my nova1624 lathe. that went well and the engineer in me has to appreciate the clever foot design on this lathe. can accomodate uneven concrete surface by swiveling and adjusting up and down....and, there are rubber inserts isolating the cups in the feet from the legs. shown upside down before assembling this last one:
    Attachment 15100
    the rubber insert is lying next to the conical threaded shaft with the foot in the rear and an assembled leg is to the rear of that leg.
    but on to my question...i have a few lidded boxes underway and have been coring the end grain with my bowl gouge. that's ok but am aware of other means and am asking for the best option. the termite seems dedicated to this task...then the monster system is attractive as it could also be used for hollow forms. how about some advice so i don't have to learn by buying the wrong stuff??? and thanks to all the experienced turners that make this site so interesting.
    99% of lawyers give the rest a bad name...Steven Wright.
    30,017
    I'm by no means experienced at end grain cutting (like in a box), but tools like the Termite or various hook tools I've seen pics of do handle end grain well. I've got the Termite, and it works as advertised, but for the pieces I've made so far, I've found I can get essentially the same result with a sharp bowl gouge. If I was doing end grain boxes, the Termite would be used more, I suspect.
    Vancouver
    191
    I use either a round nose scraper, or my Sorby box scraper. Both work great on endgrain for box work. The latter is square so my tool preference would be depending on whether I want a concave or flat bottom.
    Goodland, Kansas
    4,834
    I use Raffan's gouge with the back hollowing method he uses. Then finish with a square scraper to square the bottom.
    Bernie W.
    Decatur, Illinois
    177
    i'm familiar with the scrapers that gari refers to but only have a small one up to now. but the raffan bowl gouge description from bernie...is it this one bernie?
    http://www.woodturnerscatalog.com/st...ryo_bowl?Args=
    looks like the grind goes from pretty flat on the right side to more steep at the nose and left side. but not sure about the back hollowing description. i'm also not sure how i would sharpen one as i use the tormek usually and that jig does symetrical grinds...unless i stopped and changed the setting during the grind???
  1. End Grain Cutting Boards
    By Bill Arnold in forum Flatwork Project Showcase
    Last Post: 11-16-2014, 11:11 PM
  2. End Grain Cutting Board
    By Dan Mooney in forum Flatwork Project Showcase
    Last Post: 10-18-2012, 01:39 PM
  3. End grain cutting board oil question
    Last Post: 11-27-2010, 02:53 PM
  4. End Grain cutting boards... in progress
    By Ned Bulken in forum Flatwork Project Showcase
    Last Post: 12-29-2008, 08:19 PM
  5. End Grain Cutting boards with a different Twist
    By Dewayne Baker in forum Flatwork Project Showcase
    Last Post: 09-15-2008, 01:30 AM
