Drew,
Vouaguer is her name.
I have built two other boats, both canoes, and never had any problems with delam of the layers. My boat is stored inside in a dark pole barn, and no, I have no imbedded for posterity insects. I built mostly inside in my basement and finished in my garage of my second house I built while building the boat. Scratches are unavoidable, but just a little epoxy and poly and they disapear. I always launch from a dock off a trailer on this boat down a boat ramp.
The weight was approx 150 lbs before I installed the seats and floor boards, I would guess that it weighs approx 250 - 300 lbs now. In the water, it is very light and easy to handle. Did you check out the link to the other pictures.
I think the epoxy system was MD and it was very easy to use. Only had a couple of flashes in small pots so not too much product was lost due to slow application on my part. I do like it much better than West System.
The in side stem was made of laminated layers of black walnut and white oak. the outer stem was made of laminated layers of white oak. I tried very hard not to use staples, I used spring clamps (see the pics in the link) I did use bronze ring shank nails at the bow and stern ends of each strip, the strips were bead and coved. I used Titebond III for the adhesive to hold all the strips together, got a little liberal in the installation of the first strips and had a heck of a time getting rid of the glue squeeze out. Strips were 3/8" X 3X4".
