Results 1 to 2 of 2
Thread: Numerous Jigs for Bed Design
    I am planning a project to replicate the bed shown in the pictures below. I am fairly inexperienced with jigs and totally inexperienced with bentwood lamination. The headboard/footboard in this design is replete with challenging jig setups. Check me out on my predictions for needed jigs.
    1. Form for bentwood lamination for top curved rail, and also for curved piece below the wider top.
    2. Jig to position the narrower piece under the wider top rail piece (in order to accurately position it in the midpoint.) Attaching this narrower rail to the wider top rail is not at all obvious----dowells perhaps or just 23 gage pins, clamps and glue??
    3. Jig to assist a router to travel along the edges of the bent top rail. (I may be wrong on this one).
    4. Jig to position the bent piece in a drill press in order to index and orient the holes for the vertical dowell rods. I find it interesting that the axis of the rod will be perpendicular to the surface of the bent rail only at the centerline of the bed; the angle changes (relative to the surface) for every position, thus the jig needs to account for this......I believe.
    What else might I be missing in this list and I have mentioned something that is not really needed?
    Am I correct in assuming that this is not a trivial project? (Understatement I believe). The question is, can it be done? Ha. The real question is can I do it?
    Would appreciate some discussion and comments.
    Ken
    Attached Thumbnails Attached Thumbnails CurvedTop Bed1.jpg   CurvedTop Bed2.jpg
    ken,
    the good news is the bends are segments of a circle so making jigs-n-templates is only a matter of swinging a router on a trammell...
    which jigs do you need advice on?
    what tools are in your arsenal?
    what species and finish do you intend to use?
    can it be done? yup! can you do it? if you want to
  1. Sharpening Jigs
    By Charlie Plesums in forum General Woodturning Q&A
    Last Post: 09-22-2013, 07:22 PM
  2. Finishing Jigs
    By Steve Southwood in forum Jigs and Fixtures
    Last Post: 03-12-2011, 03:14 PM
  3. Jigs and fixtures
    By Sandra Meyer in forum Jigs and Fixtures
    Last Post: 06-22-2009, 04:22 PM
  4. DoveTail Jigs
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 01-03-2008, 01:11 AM
  5. Dovetain jigs
    By Jeff Horton in forum New Tools
    Last Post: 02-04-2007, 03:53 AM
