Results 1 to 10 of 10
Thread: Making Circle Templates on the Bandsaw, the KISS way....
    K.I.S.S. stands for "Keep It Simple.....Stupid" where the "Stu-pid" is me
    I had this idea drilled into my head by various good teachers along the way, other saying like, "When you hear hoofbeats, think horses, NOT zebras"
    .....unless you are in the Serengeti, I guess
    I had some rather NOT flat chunks of wood, I wanted to cut a circular turning blanks from, to do this, the easy way, is to have a selection of turning blank circle templates you can lay over the wood, secure it with one screw in the center and then, using the template as a guide, cut your blank.
    I wanted a quick and easy way of making some templates, I know one day I'll go to the trouble of making a really nice, adjustable circle cutting jig, but I do not have the time to do so right now, so this is what I came up with, for quick and easy.
    A piece of fairly thin MDF, I had it like this, with the sort of "L" shape to it, this works great, as there is support for the piece being cut on both sides.
    I drew a line and then I drilled holes every centimeter, this would give me 2 cm jumps in template size (7/8"?) I then pushed a small nail through one of the holes, and cut it off, and sharpened it to a point.
    I just eyeballed the set up, keep the jig square to the blade and keep the line with the holes in it, lined up with the teeth of the blade.
    I would cut the piece of scrap thin plywood tot he size I want, in this case 18cm, I find the center of the square, and then drill a small hole, same size as the nail in the center. Pop the piece on the jig, with the nail in the 18cm hole.........
    .....turn on the saw, rotate the piece and there you are, a circle template.
    I did this for 14 cm to 20 cm, and I'll do some larger sizes when I get some left over pieces of plywood from something.
    I also drilled a large hole in the templates, off center to hang them on.........
    There they sit on the wall with my blades, waiting for the next use.
    The jig cost next to nothing, took maybe 10 minutes to make and works great.
    Yep, I think I followed the KISS principle here fairly well!
    Red Deer, Alberta, Canada
    618
    Looks good, Stu! I've been using something similar for a long time but I never thought of making templates like that. I'll have to give it a try one day; thanks for the suggestion.
    Goodland, Kansas
    4,834
    They look good Stu. I am cheaper than you are. I used a cardboard box from our refrig to make mine. Hey they work.
    Bernie W.
    Jul 2007
    DSM, IA
    5,719
    Stu, if I ever get a BS...maybe someday?...I will implement the KISS method. I try to use it on everything else.
    My Website
    Inside the Beltway
    2,666
    Stu,
    Brilliantly simple solution to a problem I've been having. Never have enough time to make a full scale jig for rounding blanks, but this is easily modified to a quick and simple solution!
    Bill
    Drums, PA
    292
    Like Bernie, I use cardboard also. I have a large compass, I'm guessing it will do a 24" circle. That and a pair of scissors is all that is needed.
    Over the years I accidentally cut into the cardboard, cheap and easy to replace when needed.
    Tellico Plains, Tennessee
    4,353
    Stu,
    Good process.. I think I'll try the KISS method next time I need to cut a circle.. thanks for a good tip.
    Chuck
    Tellico Plains, TN
    Nice and simple, but effective, Stu.
    I've used paper plates for templates on uneven blanks. On relatively even blanks, I just scribe a circle with a large pair of dividers and follow that line on the bandsaw.
    Zushi, Japan
    739
    Great idea Stu. I always eyeballed the not so flat chunks but they don't come out very round. This solves the problem beautifully.
    Tokiwadai, Japan
    2,882
    Very nice, Stu....I have a couple of "Drop Lids" to build, and this jig will work great.
    (wooden lids to hold down vegetables while you cook them in a pot)
  1. Circle Jig
    By Greg Brimer in forum Jigs and Fixtures
    Last Post: 06-24-2012, 01:42 AM
  2. Bandsaw Circle Jig v3
    Last Post: 07-25-2010, 05:01 PM
  3. Bandsaw Circle Jig - Quickey Version 2
    Last Post: 08-20-2009, 04:43 AM
  4. Circle
    By Greg Cook in forum Site Questions and Test Posts
    Last Post: 01-03-2008, 08:35 AM
  5. domino templates
    By Jonathan Shively in forum General Woodworking Q&A
    Last Post: 11-09-2007, 03:46 PM
