Results 1 to 10 of 14
Thread: Router or Dado Blade?
    I'm building a utility shelf for the basement (i.e. nothing fancy) out of laminated particle board. There will be a lot of dados for the shelves. I can use either a router with a 3/4 straight bit or a dado blade in my table saw. Any recommendations ?
    Thanks, DKT
    Trinity County - 160 miles north of San Francisco. Redwood forest.
    159
    The word 'lot' applied to Dados would seem to indicate the need of a tablesaw. For a lesser number, a router would provide improved cut quality.
    I am about to invest in Festool equipment precisely to cut Dados, using their clamping table and guide rail/router combination. If I were doing production quantities, I'd spend more money on a good Dado stack and use the TS.
    Gary Curtis
    5,322
    Quote Originally Posted by Dietrich Trenner View Post
    Thanks, DKT
    By 'laminated' I'm guessing you mean melamine coated. If so, then chip-out will be a potential problem if using the tablesaw. (same also if it's a FormicaŽ type laminate).
    A router will give a cleaner cut. The downside of that, though, is (you did say a LOT of dados) that particle board is very hard on cutting tools - especially router bits. You may find that you go through two or three bits - even carbide ones - while cutting the dados. Expensive bits wear nearly as fast a cheap ones in particle board, so I'd suggest getting a couple (or more) bits from MLCS, or Woodline, or someplace like that.
    Herndon VA
    180
    Jim has a good point. You may want to try making a scoring cut at about 1/64th. Just enough to score the laminate. Then make a deeper cut. Either way I usually make several passes depending on the depth to prevent tearouts and strain on my router.
    You can essentially do the same with a dado blade. Try a few test cuts and see what you feel more comforable with. Personally, I use dado blades more than routers for dado cuts.
    I made a LOT of storage cabinets for my garage. I used a Router and straight edge. It was very fast to route across the sheets for the shelf dados, and then rip with a straight edge for the sides, top and bottom.
    These took a couple of weeks off and on with SWMBO and I working mostly on Weekends. Total 3-5 days of work, Hope this helps.
    Tom...
    Toronto, Ontario, CANADA
    2,332
    I'm another person who makes a lot of dado (and rabbets) using a router and a straight edge (Festool in my case). I used to make dados on my table saw (using a good Freud stacked dado set) but they were not as accurate or as clean. Once I tried a router, I gave away the table saw dado blades.
    Cheers, Frank
    Southern Louisiana
    947
    this could seem like more work, but it might save the router bits a little. you could possibly do a rough cut with a dado stack on the TS, let's say if your finished dado needs to be 3/4", you could plow out a 5/8" dado on the TS centered where it needs to be, then come back after with the router and take the rest off, probably leaving a cleaner cut on the melamine or formica and not putting such a strain on the router bits.
    but like i said, it may be more work than you want to do.
    you could also do a test run on the TS with a really good homemade zero clearance dado insert, this is how i do my dadoes in my ply for my cabinets and i have nearly no chip out on the sides, even when the blades starts getting dull.
    good luck with whatever option you choos.
    chris
    WNY, Buffalo Area
    873
    A down spiral router bit will help preseve the edge of your surface (melamine, formica, or even nice venier plywood). A standard straight router bit and a up spiral bit might cause chip out at the edges.
    Just be sure to take several light passes, as the chips won't be cleared efficiently with a down spiral.
    www.tinyurl.com/thewoodshoppe
    You've gotten good advice here. Pick up a few router bits, make multiple passes. If your material is not measured at 3/4" (as opposed to just called 3/4") one of these can help: http://familywoodworking.org/forums/...ead.php?t=3367
    Inside the Beltway
    2,666
    I've got the same problem. I'm about to make a bunch of pantry shelves (for the laundry room... long story... Anyway, they're going to be 48" wide, and about 7 feet tall. They'll be painted, but I haven't decided between ply or MDF yet. The reason I'm considering MDF is because a 3/4 router bit dado will leave the plywood shelf pretty loose, rattling around in the slot. I do have a dado stack, but I'd have to make a new zero clearance insert. And if I go that route, I'd be essentially crosscutting a 12 by 84 piece, several times, which could get pretty icky... not only that, but each shelf will need a 1/4 dado in the middle, since the span is so long and my beloved doorlink tends to overload shelves. I'm going to have a 1/8" back and a face frame. It's a pretty simple design, but I keep going back and forth on this same question, dado blade or router bit? Usually, when I write something out, I find I've answered my own question, but not this time...
    Bill
  1. Dado blade set?
    By Chris Marlor in forum New Tools
    Last Post: 02-20-2010, 05:53 AM
  2. Dado blade set
    By Bob Gibson in forum New Tools
    Last Post: 08-23-2009, 06:16 PM
  3. Stacked Dado Blade Set
    By jim crockett in forum General Woodworking Q&A
    Last Post: 02-18-2008, 09:11 PM
  4. Dovetails with a dado blade?
    By scott spencer in forum General Woodworking Q&A
    Last Post: 01-21-2008, 05:33 AM
  5. Router or Dado blade, the verdict
    Last Post: 12-22-2007, 06:42 PM
