Results 1 to 10 of 20
Thread: Poor Man's Mobile Bench Base
    30,008
    I've got a big hand-me-down bench that's handy as a large horizontal surface, but its large size limits where I can put it in the shop. There have been a number of times I wished I could move it, even temporarily, to make room for one thing or another. Now that I have hard surfaced floors, I'm on a mission to make a lot of my tools movable. The bench was next.
    I picked up a batch of cast iron casters with rubber tires on sale at Harbor Freight a few weeks ago. They're rated at 300 pounds each, so I figured four of them would handle anything I might load on the bench. Putting the casters on was no problem, but I wanted a way to put the bench down on its original feet when I'm not moving it. I saw something similar a few years ago on one of the woodworking forums, so this is an adaptation of someone else's idea.
    My "mobile base" consists of a scrap 4x4 stringer bolted to the inside of the bench legs. Attached to that with a pair of door hinges is a scrap 2x4, and mounted to that are the casters. When the wheels are in the "down" position, the legs are about 1/2" off the ground. These pics show one end of the bench. The other end is the same.
Name:	Bench Wheels - 01 800.jpg
    Here's a shot from the inside. The hook and eye screw prevent the hinged portion from folding when moving the bench and dropping the bench back down on the legs. DAMHIKT. The big empty eye screw will be explained in the next pic.
Name:	Bench Wheels - 02 800.jpg
    To switch from "mobile" to "fixed", I hook a bungee cord to the large eye screw on the hinged 2x4, wrap it under the contraption and hook it to a hole in the table apron.
Name:	Bench Wheels - 03 800.jpg
    I don't have a sophisticated lift system, but the ol' Handyman jack does the trick.
Name:	Bench Wheels - 04 800.jpg
    Once it gets high enough (about 2 clicks of the jack), the wheels swing around, and the bench is ready to be set back down on its feet. (Sorry for the poor focus...I was holding the jack with one hand, and shooting without a flash with the other.)
Name:	Bench Wheels - 05 800.jpg
    Back down on terra firma, it's as if the wheels were not there at all. (Except the stringer adds some rigidity to the bench that wasn't there before.)
Name:	Bench Wheels - 06 800.jpg
    And another inside shot, showing the feet are indeed all the way to the floor. No tricks or mirrors.
Name:	Bench Wheels - 07 800.jpg
    The bungee is not quite tight enough to keep the wheels up firmly, so I use the hook latch to add a little tension to things.
Name:	Bench Wheels - 08 800.jpg
    The bench goes back on the wheels by reversing this process. I just unhook the bungee and wrap it the opposite direction around the hinged part, jack it up a couple clicks, and the wheels go into place, although they don't snap into position the way I'd like them to. My goal is to make it so that I can simply lift the end of the bench (without the jack) for a a second and have the wheels snap either up or down, depending on the bungee orientation. I plan to play around with the placement of the bungee cord to see if a different angle (farther under the table) might work better. Still, even as it is, it solves the mobilization problem for me, despite the rather jury-rigged appearance.
    Well done, a nice KISS approach to solving the problem!
    Lake City, Florida
    498
    Cool Vaughn, I've thought of the idea many times but never figured out how to attach underneath the legs -- never thought of attaching to a stretcher !!
    I'm usually great on ideas -- good on design, but very much lack in simplicity (guess that's the engineer in me -- build them to last forever and withstand anything).
    Thanks for posting -- I feel added mobility coming on
    Tony.
    Tony, BCE '75
    30,008
    Quote Originally Posted by Tony Falotico View Post
    ...Thanks for posting -- I feel added mobility coming on
    Tony.
    I happened across this article tonight while looking for something else. It's a similar idea, but a bit more refined. (Although my version is bearing the weight more directly on the wood, and not on the hinges. My bench is real heavy when loaded, so I wanted some beef supporting the casters.) And from this article I see Nahm has done other versions of the same idea. Just thought the more variations you see, the more likely the engineer in you could come up with something you'll like.
    Looks like it will work great to me. Well done.
    11,825
    Whatever floats yer stick. It works! That's all that counts.
    Jul 2007
    DSM, IA
    5,719
    Vaughn, Well Done I saw something simialr for a mobile TS bench, but then I figured out how to use my lathe...not sure I will ever make it now.
    My Website
    Waterford, MI
    773
    Cool. Nawmy did something similar on one of the NYW episodes years ago. I've also seen somewhere a trick of putting only 2 casters on one end and have them not touch until the table/bench is picked up a bit on the other end. The other end was then hiked up with a wheeled Johnson bar setup (somewhat like the Minimax bar).
    Good work
    Vaughn, that mobile base should withstand anything but a direct bomb hit.
    Norm, a few brads, Abram would be proud.
    Is it safe to say that the 4x4 was something that was just laying around?
    30,008
    Quote Originally Posted by Ken Garlock View Post
    ...Is it safe to say that the 4x4 was something that was just laying around?
    Yep, it was scrap left over from a project several years ago, and the 2x4 was part of the packing materials my new lathe came in. Aside from the casters (about $4 each on sale) and the hinges, the rest was stuff I had laying around.
  1. Mobile base on a TS?
    Last Post: 07-07-2011, 12:38 AM
  2. Mobile tablesaw base
    By Alan Bienlein in forum Carpentry and Construction
    Last Post: 02-27-2011, 09:45 PM
  3. Mobile Base for Joiner
    By Sean Wright in forum Jigs and Fixtures
    Last Post: 07-02-2010, 10:09 PM
  4. mobile base for the new bandsaw
    Last Post: 11-24-2009, 10:01 PM
  5. Rockler Mobile Base - $29
    Last Post: 11-28-2007, 04:53 PM
