Results 1 to 10 of 13
Thread: Cutting Laminate Countertop ?
    Charlotte, NC
    1,487
    I have a couple countertops I need to install and they will have to be cut to length. Do I need to buy one of the specialty laminate blades. I'll be using an older circular saw. My plan is to tape the laminate and cut upside down. I also have a backsplash to deal with. Any advise will be appreciated!
    Tokiwadai, Japan
    2,882
    Ed,
    I built a quick jig, taped the laminate side. Worked great for both the top and the backsplash. I didn't use an special blade.
    When I cut laminate countertop, I use a router to cut through the laminate that way I reduce chip-out, then cut the rest of the wood underneath it with a circular saw.
    Charlotte, NC
    1,487
    Thanks guys! I'll let you know how it goes today!
    If you are sans router, consider the tape and Score the laminate with a utility knife.
    Houston, Texas
    2,323
    I agree with Greg.
    Shaz
    Please join me. Register now.
    Shaz
    Here is how
    Charlotte, NC
    1,487
    Followed Greg's method. It worked quite well! Thanks! I hope to finish this job up this weekend.
    Smithville, TX
    358
    If you have a fairly steady hand and a good jig saw, use a downcut blade, you'll get great results. When I cut any top to length, lam or not, but especially if it is going into a wall or wall to wall and will have a backsplash -- only be carefull on the 1st inch or so of cut from the front, and take an extra 1/4" (like a dog ear) off the rest of the way back. Cut doesn't really have to be that straight since it will be coverd with a backsplash anyway. Makes install a breeaze, you don't have to worry about interior corners having more mud or out of square walls. Just the front edge has to look tight. If you are going wall to wall with no backsplash and you want it to look tight -- I'll still use a jigsaw, make it a 5 degree bevel, so I get more of a razor edge to butt up to the wall, then figure what your scribe line will be (no straight walls) and again use a downcutter. If you don't feel that confident with a jigsaw, then cut outside the line and block sand to the line (with the more razor like edge sanding goes pretty quick) Go ahead and be precise, with most walls you can lean on them enough to squeeze a top in, then let them spring back. Nothing like a joint that doesn't need caulk. Very few will notice, but you will know.
    Mini Max Tool Acquisition Mediator.
    "An old man to most kids and a young man to those who are dead."
    www.samantics2.com
    Charlotte, NC
    1,487
    Thanks Sam, I'll keep your method for reference! I will be breaking out the jigsaw tomorrow for the sink cutout. Not really fond of countertops, but you do what you gotta do!
    Nov 2007
    Burton, Mi
    4
    If you are going to have some left over material you can do a practice cut. I believe in the past I have taped and scored it with a utility knife to minimize the chipping, I also believe that I cut if from the bottom for a clean cut. Good luck....
  1. Replacing kitchen countertop
    By Tom Baugues in forum Carpentry and Construction
    Last Post: 09-30-2012, 10:40 PM
  2. The making of Jarrah Countertop
    By Tom Niemi in forum Flatwork Project Showcase
    Last Post: 07-11-2009, 01:34 PM
  3. Replies: 25
    Last Post: 01-31-2007, 12:17 AM
  4. Countertop Mod
    By Ed Nelson in forum Carpentry and Construction
    Last Post: 12-12-2006, 12:27 AM
  5. Laminate floor cutting jig.
    By John Pollman in forum Jigs and Fixtures
    Last Post: 11-08-2006, 12:30 PM
