Results 1 to 8 of 8
Thread: Sizing Shelf Pins
    Trinity County - 160 miles north of San Francisco. Redwood forest.
    159
    Sizing Shelf Pins
    I foresee boring a lot of shelf pin holes next year, and thought using a plunge router rather than drilling, would be the ticket.
    What size do you bore for shelf pins.
    Lee Valley sells 5mm pins, 5.5 mm sleeves, 1/4" paddles with 5/16" sleeves.
    Are the sleeves for softwood?
    Gary Curtis
    535
    The sleeves go with the 1/4" pins or paddles and give it a more finished appearance. One gotcha with sleeves though, is then the pins fall out more easily, but if your shelves are flat and your holes are straight thats not a problem.
    I always use the sleeves, because it looks so much more 'finished'... and have found that the pins go in easily part of the way, and 'lock' in once they're all the way in place and are quite tight.
    I think they also sell the pins and sleeves in standard and metric, which may account for a loose/tight fit.
    Southern Louisiana
    947
    gary,
    i tried the router and hated it....the bits would always burn the wood. i was going to try an upspiral bit to help with cleanout, but then i saw this.
    http://www.rockler.com/product.cfm?page=5876
    fairly cheap, and fool proof. takes less time than with a router and it's quiter.
    i used this alot before i bought my boring machine
    chris
    almost forgot, it comes with a 5mm bit or a 1/4" bit.....also you can buy the appropriate bit for using the sleeves for each size. i prefer the look of the 5mm because it's a little smaller
    Long Hill Township, NJ
    467
    Gary:
    I also used the Rockler drill jig Chris suggested to build a triple bookcase for the home office. I had a liitle tearout issue with the veneer on the oak ply. I think I reduced that by changing the drill speed - can't remember if it worked better faster or slower (sorry).
    I think the holes look "ok" without the sleeves, but I'd consider using the sleeves on my next shelf pin project.
    Hope this helps.
    Jim
    Southern Louisiana
    947
    jim i had some issue with tearout too, it was worse on cheaper plywoods and better on nicer veneers. i was going as fast as i could, because for me time is money, so i would think slow would be better.
    Often I use shelf pins, Never have I used the inserts, I made a jig from some scraps of 1/4" peg board. I skip every other hole making my incruments 2" apart I use a stop block on the drill and bore exact 1/4" holes. Sand a bit and finish properly the results are smooth holes with a slight bit of finish inside that makes for a tight 1/4" fit. Looks good, works fine, why bother with the inserts?
    Jul 2007
    Grove City, Ohio
    57
    I use the 1/4" pins without the inserts and have not had any problems. I use a home made jig and the DrillRite bit from Woodcraft. This bit has a brad point type of bit and tear out has not been a problem. I do use a high speed drill with the bit.
  1. Pentz blower sizing
    Last Post: 05-02-2016, 01:44 AM
  2. Funeral Urn/Box Sizing?
    By David Agnew in forum General Woodworking Q&A
    Last Post: 08-21-2015, 04:31 PM
  3. Air compressor sizing
    Last Post: 04-01-2011, 12:58 PM
  4. Between down sizing my shop
    Last Post: 02-25-2010, 01:45 AM
  5. Sizing down glass
    By Doug Jones in forum General Woodworking Q&A
    Last Post: 12-11-2006, 09:48 PM
