Results 1 to 10 of 10
Thread: Sanding paper....everywhere
    Nov 2007
    Poland
    267
    Good day
    If you did not see me posting lately, it's because I went for a few days to Israel but, I'm back...in one piece
    I would like to share with you a few things that I do with sanding paper.
    On one of the pics, you will see that I'm gluing the Carpet Tape to a strip of sanding paper. Actually, I took an A4 sheet and glue the carpet tape all over it and than, glue it and trimmed. That saves carpet tape and sanding paper.
    Regards
    niki
    Central NY State
    3,374
    Thank YOU Niki.
    Ken
    Nov 2007
    Nashville, Ar.
    53
    Hi Niki, I like very much what you do with the sand paper, I'm sure I will put some of those to work with me.
    Sure would like to have been in your back pocket when you went to Israel, it has been my dream for a long time. Jack
    Thanks Niki. I particularly like the curtain rod trick. Once again, you're thinking way outside the box.
    Nov 2007
    Poland
    267
    Thank you for your kind replies
    Jack
    Everything is relative.....I lived in Israel for 45 years so it's not exactly "exciting" for me.....but, if you'll tell me Arizona, the Great Canyon etc...I would love to go there...
    Regards
    niki
    5,175
    Arizona is my home state. You are welcome anytime after I get back there in August.
    WNY, Buffalo Area
    873
    Niki,
    Those are some great ideas!
    I'm impressed that you were able to work that piece with all of the various tools with little to no movement.
    That towel rod trick it is especially innovative. Its so simple, I would have never thought of that.
    www.tinyurl.com/thewoodshoppe
    Nov 2007
    Poland
    267
    Thank you so much
    Carol
    Thanks for the invitation...the truth is that I became lazy and like to stay at home...just thinking about the flight, puts me off...
    Sean
    The towel rod idea came from Japan...as you know, Japan is the "earth quake country" and we were "clamping" down all the cabinets with kind of a "screw jack" very similar to the towel rod...so, if it can hold the cabinet....
    Regards
    niki
    17,475
    thanks again niki!!!!
    but i saw an example of an idea i am in the middle of puttin together and figured i would ask you to show us your solution...its your home vacume setup there in the black box..i had scavanged one from the waste truck and figured i could use it as a sanding vac..had the idea of puttin it in box like you have./. so could you show us your vac system... thanks abunch.
    Nov 2007
    Poland
    267
    Thank you Larry
    What a sharp eye....
    I will post it soon on a new post not to load this post with too many pictures (takes long time to open)
    Regards
    niki
  1. Sanding Disk paper removal
    Last Post: 09-09-2012, 05:16 AM
  2. Paper Gloat
    Last Post: 10-21-2011, 08:43 PM
  3. Chiyogami paper
    By Mason Kuettel in forum Lathe Project Showcase
    Last Post: 02-19-2011, 02:00 PM
  4. how do you paper mount?
    Last Post: 04-06-2009, 01:06 AM
  5. ROS Paper Holder
    Last Post: 03-14-2008, 09:37 AM
