Results 1 to 8 of 8
Thread: Delta rinky dink
    Palm Beach Gardens, Florida
    185
    Delta rinky dink
    OK now no one laugh but I just unpacked a new Delta planer. This is the smallest and cheapest one they make, 6" "ShopMaster". I am going to be using it to finish some SYP 2" x 12" that I am ripping to make the bench top and base for my workbench.
    Now to my question. I tried it on a 2x4 stud on edge and one face. It works. I have checked the squareness of the fence to the table and found it to be spot on with the infeed table but not with the outfeed table. Then I saw that the fence appears to be square but the outfeed table is not even in alignment with the infeed table. There are four screws in the surface of the outfeed table. I am assuming I can loosen them and then adjust this table to both the infeed table and the fence. Does anybody have any experience with this planer or one close to it that could lend some advice?
    The manual only discuses readjusting the fence but that is not the problem here.
    Regards,
    Bill Antonacchio
    The Heart of Dixie
    4,268
    You said planner but you describe a jointer?? I assume you meant jointer?
    Custom built boats and Kits
    185
    Yes, I must have planer on the brain, I DID mean jointer. Thanks Jeff.
    Regards,
    Bill Antonacchio
    Vancouver
    191
    Hi Bill,
    I had the same jointer when I first started getting into woodworking, and had the same issue. I ended up shimming the outfeed table by using some old playing cards until it was level with the infeed table. If I recall correctly, I punch holes in the cards and used them like washers were the screws attach to the end of the table.
    Good luck!
    -Gari
    185
    Thanks Gari.
    Regards,
    Bill Antonacchio
    Aluminum cans work good for shims as well.
    Good luck with it, even though it might be a bit "rinky dink" as you put it, it can still do good work, if you know it's limitations and work within them.
    ps..............
    No pics............ yeah, you know...... did NOT happen dude!
    185
    Hi Stu,
    Thanks for the tip and yes I know the rule!
    By the way my nonexistent Dewalt bench top table saw is a problem too. I over turned the fence knob beyond where I can adjust the little measurement gauge. Any ideas how to get it back within the range of adjustment? (it may not exist but it DOES look like yours)
    Regards,
    Bill Antonacchio
    Hi Bill
    Did you skip a tooth on the back rail thing on the saw? if you did, you can use a screw driver to pry (CAREFULLY) down on the shaft that holds the small gear that rotates to move the fence, it is actually held against the toothed rail by a spring, then you can get stuff lined up again. You can also align the fence by loosening two bolts under the back of the saw's table, mine has two arrows marking the location of the bolts, they are 10mm, then move the back end of the fence until it is square with the blade, lock the fence in place and tighten the two bolts.
    I'll take some pics if I can later, I hope to get down to the Dungeon tonight for a short time.
  1. Delta Planer - DELTA 22-795X 15-inch\ 3 HP
    By Doug DeVore in forum Hot Deals
    Last Post: 01-09-2013, 02:27 PM
  2. Delta 990 RAS
    By paul newton in forum Old Ads
    Last Post: 02-11-2011, 12:46 AM
  3. New to me Delta DJ-20
    Last Post: 01-14-2010, 01:42 AM
  4. TPI on delta Midi?
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 12-29-2008, 08:33 PM
  5. Delta DC - 50-850
    By Matt Guyrd in forum Hot Deals
    Last Post: 02-25-2007, 09:42 PM
