Results 1 to 5 of 5
Thread: Cheap "Grip-it" clamps repair and improvement
    Nov 2007
    Poland
    267
    Good day
    Sometimes, we are tempted to buy cheap stuff just because it's....cheap...
    That's what happened to me and after using them a few times, I noticed that the jaw is sliding back and the handle hinge housing is breaking....
    I changed the handle hinge with a bolt and nut and grind the narrow sides of the bar with #40.
    The repair was so good that I made it immediately on all the clamps, even the "good" ones...
    I hope it will help some of you "cheap guys".....like me
    Best Regards
    niki
    Jan 2008
    Riverview, FL
    7
    Niki I had a similar type of a Quick clamp that was beginning to slip, but not anymore after I followed your tip here.
    Simply roughing up the bottom of the bar with sand paper as you suggested made it work again as the manufacturer intended.
    Thanks again for sharing the info.
    Carl
    Great that you took the effort to show this but it doesn't help my situation where the (exact same cheap clamps) ends break off. No fixing there...
    Goes back to old addage, "you get what you pay for"....
    17,470
    you just got to much
    GRIPPPP! see some folks that those cheaper ones were made for have less grip power
    Great info Niki. I've got a similar set as back-ups/extras. I'll keep your upgrades in mind if I end up using them a lot. Actually this is good info even for "good" clamps!
    Thanks for posting!
    Wes
  1. "Crime Doesn't Pay" or "No Good Deed Goes Unpunished" ?
    Last Post: 11-21-2013, 05:57 PM
  2. "Toggle" Clamps for Jigs @ HF On Sale
    By Norman Hitt in forum Hot Deals
    Last Post: 03-21-2009, 02:32 AM
  3. 4th Annual WorkShed Clean-Up and Improvement "Week"
    By Frank Pellow in forum Carpentry and Construction
    Last Post: 11-29-2008, 12:02 PM
  4. "F"-Clamps $4.99
    By Don Taylor in forum Hot Deals
    Last Post: 05-03-2007, 07:34 PM
  5. 1/2" vs 3/4" Pipe clamps
    By Al killian in forum Hot Deals
    Last Post: 12-26-2006, 01:29 AM
