Since i only have one blade for my MM16 (Lenox TriMaster) i'm looking for a backup and am considering a 3/4" woodslicer from Highland Woodworking.
Any opinions?
Thanks!
Brian![]()
Any opinions?
Thanks!
Brian![]()
........not all those that wander are lost
Brian, when I ordered blades from Louis Ittura I asked about the woodslicer and was told that he had an equivalent blade in 1/2 ". I bought one and while it worked okay I won't buy another one since it seemed to dull pretty quickly. I may be wrong, but my understanding is that the woodslicer is most useful for re-sawing on smaller saws since it is thinner than the regular blade and does not need as much power as a normal width blade. You've got plenty of power with the MM, so why not get a good 1" bi-metal or even carbon blade as a back-up.
brian, if i`m not running a trimaster i`ll shop for price on hss blades....as long as the tooth geometry is what you need the life from one to another will be just about a wash.....tod
associated with several importers and manufacturers.
Thanks Guys!
My first thought was the woodslicer because it does so well my 12" Atlas but you're right, just about any variable tooth blade would be a good backup. I'll look around for a 1 - 1.25". MiniMax has Olson All Pro's for $35.
BTW, MM has a couple videos on their site that addresses some of the basic setup steps for their bandsaws.
Brian![]()
