Results 1 to 10 of 14
Thread: Cleat Mounted Clamp Rack
    After a few variations over the years I have settled on this assembly as a 'standard' cleat mounted clamp rack. The width and depth of the slots will hold K-Body to 4" F-clamps. Eight clamps per 15 3/8" wide fixture. Thought this might help keep some folks from reinventing the wheel. The wall mounted cleat is shown in the pic and in the file.
    Attached Files Attached Files
    Toronto, Ontario, CANADA
    2,332
    That's a good design Glenn! I will keep your design in mind should I ever need any additional clamp racks.
    Cheers, Frank
    Well, here's a lot to say about a little bit. I wanted the spacing consistent so here's what I did:
    Cut up some blanks for the piece that will actually hold the clamps and laminated some hardboard on top to take the abuse. I used some old pegboard that I had laying around. Hey, they're just clamp racks.
    I made some setup blocks to perform the offset and tried them out, shimming till I got consistent spacing without an accumulated error.
    Now that I'm ready I place the edge of the first blank against the blade to determine my zero position.
    Clamp the blank and use the setup blocks to position my stop block.
    Slide the blank over and make the first cut (I'm using the dummy here to give you a better idea of where I'm headed).
    Clamping the blank I use a setup block to reposition my stop block.
    Remove the block, slide the blank over and make the second cut.
    Now just do that a whole bunch.
    Man I can be a long winded son of a gun about nothing, can't I? Cont'd ===>
    I wanted the back of the slots rounded so to same some effort I drilled them.
    I use the same setup blocks to shift the blank across the DP table.
    Then choose your weapon to finish the cuts. I used the BS but a handsaw would work fine. I used this sequence so the little cutouts wouldn't become projectiles if suddenly set free by the last cut on the TS.
    Over to the router table for a little chamfering. I used a small chamfer bit that is normally used in the Colt because the bearing would fit down the slots. The chamfers, of course, keep the edges from getting beat.
    I used a 2 degree slant and this seems more than adequate.
    I used 2 1/2" screws in 3 spots. This is a dry-fit and the parts will be glued if this works out OK.
    Looks pretty much like the SU drawing at the start of this thread. All dimensions remained as designed in the drawing if that will help out.
    And I'll just hang it here for a photo. I can put this and his five soon-to-be-completed buddies anywhere along the cleats. I plan to drill a hole for a pin that will go through the main board and protrude just under the wall mounted cleat. This will prevent the rack from getting lifted up off the cleat and spilling clamps all over the floor (or on my foot). The weight of the clamps holds the rack securely but I do empty my current racks as I'm working and I just want to be safe.
    I'll take this guy apart, finish the rest of the other parts and glue them up and seal them. The six units will take care of 48 clamps.
    30,017
    Man, that's gonna be slick, Glenn. Nice job on the pictorial, too. Thanks for going to the trouble to post it.
    I considered French cleats for my clamp rack, but I've got limited wall space, so there was really only one logical place for the rack to go. I ended up just lag-screwing it to the wall.
    Thanks Vaughn. My current racks are lagged to the wall just as you describe. That and poor lighting were part of what drove me to re-do the one wall and mount the cleats. I plan to do the opposite wall as well but something will have to force me into it ;-)
    Albuquerque, New Mexico
    1,099
    Great post Glenn. I did something similar sans cleat for my bessy’s.
    friend...if you have one."
    one."
    13,448
    Glenn,
    Great idea, thanks for posting. Looks like the wall cleat is about 5' off the floor?
    Glenn,
    Thanks. One at about 7', one just shy of 5' and one to go at a height that will allow "floor" standing cabinet height surfaces. I pre-made all the cleats and stand-off blocks so I could add them to the opposite wall once I get to it as well. I've already found it very convenient to be able to move things around quickly and easily as I settle in to the new layout.
    Just kind of an update as to how this system is working out. I needed a little more room on the opposite wall so I just tossed a couple more fixtures on this wall and loaded the stuff there. It should get more organized and static once the opposite wall is done. I still have to put the lower cleat on this wall and I'm already talking about the other one??? Dreamer.
  1. Cleat Hung Clamp Racks V2
    Last Post: 12-12-2014, 02:54 AM
  2. Clamp Rack
    By Jay Caughron in forum Jigs and Fixtures
    Last Post: 09-02-2013, 10:17 PM
  3. Clamp Rack
    By Bob Gibson in forum Jigs and Fixtures
    Last Post: 01-03-2011, 09:58 PM
  4. Another Clamp Rack
    Last Post: 08-12-2007, 12:51 AM
  5. Clamp Rack
    By Don Taylor in forum General Woodworking Q&A
    Last Post: 05-23-2007, 05:35 AM
