Results 1 to 4 of 4
Thread: Frued Inlay Set
    Fredericksburg, VA
    161
    Frued Inlay Set
    I'm in the market for a good inlay set, and was wondering if anybody knows if the Frued FT1500 Inlay Template Guide Set works with the Hitachi M12V router? Any help would be greatly appreciated!!
    - Keith
    "Listen, here's the thing. If you can't spot the sucker in the first half hour at the table, then you ARE the sucker. "
  2. Keith,
    If your router will accept Porter Cable style template guides then the Freud Inlay set will work. Some routers require an adapter to allow the use of the guides.
    I will say this, the Freud Inlay set works beautifully. With one caution. The tiny 1/8" stright cut router bit is very fragile. I have since gone to a slightly larger bit, you can't do the finer inlays, ie sharp points etc, but it will hog out the majority of the wood, and then you can change back to the small bit if need be.
    Fredericksburg, VA
    161
    Thanks for the information, guys!!
    - Keith
  1. String Inlay
    Last Post: 12-17-2009, 03:53 PM
  2. wood inlay
    By Peter Lyon in forum General Woodworking Q&A
    Last Post: 12-02-2009, 02:31 AM
  3. Inlay help
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 04-08-2009, 08:32 AM
  4. inlay kit
    By Eduard Nemirovsky in forum General Woodworking Q&A
    Last Post: 07-15-2008, 10:21 PM
  5. 1st Inlay
    By Ed Nelson in forum Flatwork Project Showcase
    Last Post: 08-14-2007, 01:10 PM
