Results 1 to 6 of 6
Thread: Peppermill Blank Question
    Mason Michigan
    455
    I would like to try my first peppermill. Can I use green wood or burl or does the wood have to be dry? If it does have to be dry, how could I dry some of the burl I have?
    thanx,
    Pete
    Pete....I've turned my peppermills with dry wood.
    Ken
    Goodland, Kansas
    4,834
    Pete I have did several Peppermills. Dry wood iis the way to go and I do use kiln dried wood. I would say the burl should be as dry as the kiln dried stock but that is just my opinion. If the wood moves it could jam up the mill. Yep I tried it. Make sure when you make go to make the mills, drill your holes first then turn them.
    Bernie W.
    North Ogden, Utah
    348
    Because you're going to want to maintain a tight fit where the top piece of the mill fits the lower piece, you'll want something that isn't going to warp or distort. You could try roughing the pieces down to something close to finished size and then do the DNA soak or even some 60 second rides in the microwave until it doesn't boil anymore. The burl wood I've turned so far doesn't seem to crack or warp so much as some wood but does shrink as it dries. That would mess up a peppermill I think.
    lutefisk capitol, USA
    485
    i have a heat vent in the basement that comes off and just happens to have some wood strips befind it. i lay wood i want to dry on the strips and let the furnace do the rest, usually only a couple days. beale has a good booklet out on making peppermills. like bernie says, drill your holes first.
    dale
    Tellico Plains, Tennessee
    4,353
    I rough my blanks round and oversize before I drill... mostly so they will fit in my scroll chuck for the drilling.. then use jam chucks to turn to shape.
    If you drill them square then put on the jam chucks they have a tendency to slip some..
    But definitely agree the wood needs to be dry..
    Chuck
    Tellico Plains, TN
  1. Peppermill
    By Peter Lyon in forum General Woodturning Q&A
    Last Post: 09-23-2010, 01:21 AM
  2. Elementary Turning Blank Question
    By Cynthia White in forum General Woodturning Q&A
    Last Post: 07-30-2010, 04:20 AM
  3. Beginner's Turning Blank Question
    By Sean Wright in forum General Woodturning Q&A
    Last Post: 01-13-2008, 11:59 PM
  4. 3rd Peppermill
    By Ed Nelson in forum Lathe Project Showcase
    Last Post: 01-04-2008, 05:53 AM
  5. Blank Question
    Last Post: 06-30-2007, 04:51 PM
