Results 1 to 10 of 16
Thread: DoveTail Jigs
    Sep 2007
    Plainwell, Michigan
    4,857
    DoveTail Jigs
    Happy New Year Everyone!
    I am building kitchen cabinets and am geting closer to the drawer stage. I will be using dovetail jointery on them and would like sugestions on dovetail jigs. I have been looking at Leigh Super Jig 18". Is this one OK? Other ones better/worse?
    Thanks, Tom
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    I have the PC4212 and I like it. It is simple and tails and pins are cut at the same time on the half-blind. I haven't tried full dovetails with it yet.
    Brentwood, TN
    294
    I have both an Incra Ultra and Leigh D4. Both will make perfect DTs. Incra is easier for HBDTs but, less flexible about placement and the Leigh is better for through DTs. All that said, if I could only have one it would be the Leigh.
    Member; Society of American Period Furniture Makers
    I have a small Rockler which is servicable as long as evenly spaced DT's are OK. If I was doing a project of your scope I would want adjustable guides. Owners of better jigs will chime in and help, I'm sure.
    17,472
    Thumbs up DOVE TAILS
    boy tom yer lookin better everyday got a leigh if you wanta use it! that way you can test drive before you buy. seen a porter cable in action and have heard great things about the akeda.. but leigh has got alot of belivers.. simplicity not! till you have used it awhile to get used to it but the verstality is great.. you could hand cut them as well. how many drawers you got? give me a call if you want to use the leigh. i am home today if your headed out this way have fridge need empting
    Jul 2007
    Florida Keys
    86
    I have both the Leigh and the Keller. If everything you are making is of equal spacing based on the Keller, you are good to go. Easy to use. On the other hand the Leigh is fully adjustable to any dimension and different wood thicknesses. The manual with the Leigh is also one of the best on any tool that I have ever seen. Very well written and easy to understand. My vote is for the Leigh.
    I've got the Keller and for simple evenly spaced through dovetails it is hard to beat. Easy to use as well.....
    Here is a pic of the first dovetails I ever cut with the Keller jig, took about 30 minutes the first time, then a LOT less time after that..........
    Don't have any other dovetail jigs to compare it to.
    Sep 2007
    Plainwell, Michigan
    4,857
    Thanks all for the input, looks like I have some investigating to do on all the different models, some I havn't heard of. Just want to be sure they can cut the pins and tails together, sounds like to me that that should be the most sure way they will fit, and quicker
    Larry, I would definitly like to see and try out your leigh, and help with your fridge problem, but it will have to be a different day as we are going to celebrate my oldest granddaughters 10 b'day today, she's the one getting better looking every day, not this old codger.
    Also Larry, there will be 16 drawers.
    Tom
    17,472
    any time TOM
    your always welcome if you like i can bring the manual along tommrrow and you can get a look at it. if you want to d botha the same time the leigh isnt the one for that, you have two setups for it to do half blinds. the porter cable does do both i think but yu havent got the flexibilty. you need to go to woodcraft or a wood show to see the differnces up close. but your still welcome to use the leigh. anytime... later frosty
    Floydada, Tx
    1,941
    I have the CMT dt jig, but looking at woodcrafts site it seems the price had shot up. When I got mine last year the price was around $100, now it is $199 tThe only problem that I had with it is thebar that hold the stock down used to let the stock slide. To solve that, I place 120 grit on the under side of both bars.
  1. Sharpening Jigs
    By Charlie Plesums in forum General Woodturning Q&A
    Last Post: 09-22-2013, 07:22 PM
  2. Finishing Jigs
    By Steve Southwood in forum Jigs and Fixtures
    Last Post: 03-12-2011, 03:14 PM
  3. Jigs and fixtures
    By Sandra Meyer in forum Jigs and Fixtures
    Last Post: 06-22-2009, 04:22 PM
  4. Numerous Jigs for Bed Design
    By Ken Close in forum Jigs and Fixtures
    Last Post: 12-14-2007, 10:12 AM
  5. Dovetain jigs
    By Jeff Horton in forum New Tools
    Last Post: 02-04-2007, 03:53 AM
