View Poll Results: Sharpening system, what your choice.
Voters
40. You may not vote on this poll
  • work sharp
    3 7.50%
  • MkII
    8 20.00%
  • Stones
    10 25.00%
  • Sand paper & glass
    9 22.50%
  • other
    10 25.00%
Results 1 to 10 of 18
Thread: opinions wanted! tool sharpening
    17,470
    whats the pros and cons of the work sharp vrs the mkII?
    what do you use? stones? paper? or machine?
    Constantine, MI
    7,888
    Sandpaper and marble tile - 1$ a piece at HD and they will make the first cut (in half) for free. What can I say - I'm cheap.
    I was looking at the Worksharp just the other day and read a recent review. Maybe - if funds allow - someday.
    www.wrworkshop.com
    larry,
    i said "other"...........learn with any system that doesn`t use guides, once you have your technique down you`ll be able to sharpen with any type of stone or system. it`s like riding a bike.....hurts like the dickens when you crash but before long all you remember is the wind in your face.....
    Charlotte, NC
    1,487
    I put sand paper, which is what I use for basic sharpening. If something really needs some work, it'll hit the grinder. Then strop the edge. Stropping makes a world of difference and if you keep your strop handy, you won't have to sharpen as much!
    Eaton Rapids Michigan
    40
    I use sandpaper also. Seems to work best right now. Would like to get something later on to help speed things up a bit.
    Bill
    I use only flat cutters so sandpaper and glass work for me along with the Veritas MK-II jig ($about $50). My dad has the work sharp (about $200) and when things need more than a touch up I can do a set of chisels in about a half hour a few times a year. Both methods use a registration system so I hae no problem keeping and repeating the angles. On the plates; I'm still working through my first $20 worth of micro abrasives sold as a 'Scary Sharp' set from Tools for Working Wood. If I give a tool a touch up for just a few minutes as they start to lose their razor's edge, they stay sharp and ready for use for quite awhile. Like Rennie, I use a cut piece of 12" x 12" marble for the heavier grits.
    Albuquerque, New Mexico
    1,099
    You’re going to laugh…I bought the Veritas® Mk.II Power Sharpening System for SWMBO a few years ago. She briefly thought she wanted to be a wood carver.
    Anyway, I don’t see how sharpening could be any easier than the MK.II.
    Size matters, the Work Sharp’s 6” disk can only accommodate up to a 2”, #5 blade where the MK.II’s 8” disk allows for up to 2-3/8, #7 blade. I use it for my plane blades and chisels and it works like a charm. The build quality of the all metal, Canadian made MK.II is excellent.
    The January `08 issue of American Woodworker gave the Work Sharp “Best Buy” and the MK.II “Editors Choice”
    friend...if you have one."
    one."
    17,470
    Quote Originally Posted by Bruce Page View Post
    well dad hasnt let me see the jan isue yet bruce rt now its been stones and paper but was shown the mkII by a couple of elders and was looking that way but havnt decided yet. my wife isnt intersted in one unless it could sharpen scissors real good
    11,825
    I have tried, and continue to try, a variety of sharpening devices and gimmiks. For knives, flat Arkansas stones or the Razor Sharp system. For turning tools, an 80 grit blue wheel or 1" belt sander/grinder, neither of which give the best results I want.
    5,319
    I've never used the MkII, and have only seen/used the Work Sharp once - at a demo where they let me try the machine on a chisel.
    The Work Sharp worked very well, but since I have a lot of planes - many of which are 4½, 5½, 6, 7,or 8 - which have blades wider than the WS can handle, I didn't find it useful enough for me.
    For about the past six or seven years, the Tormek has been my primary sharpener. It would handle every plane iron except the #8, and could be adapted for the 8, too.
    Just a couple months ago, they came out with a new jig (about $45) that handles not only all the plane irons, but will even handle things like the 12/112/80 scraper blades, too. I got mine about mid-December and have been using it since then, with the usual good results from Tormek.
    For lathe tools, or grinding a whole new bevel, the Tormek is painfully slow. I use a Woodcraft 8" slow speed (1725 rpm) grinder, and a Wolvering setup for that.
    Bottom line - the Tormek is the more versatile, but if you're doing only chisels and <2" plane irons, I'd go for the Work Sharp. It really does a good job. BTW, the WS can do wider blades, they just have to be free-handed on the top of the discs.
    Okay - that's my (somewhat biased) opinion. YMMV...
  1. opinions about TRITON router wanted
    By Dewayne Baker in forum New Tools
    Last Post: 11-24-2008, 08:30 PM
  2. Turning opinions wanted
    By Jeff Bower in forum General Woodturning Q&A
    Last Post: 07-17-2008, 12:07 AM
  3. opinions wanted!
    Last Post: 06-23-2008, 09:57 PM
  4. Checker Board - Opinions Wanted
    By John Whittaker in forum Flatwork Project Showcase
    Last Post: 08-22-2007, 01:51 PM
  5. Opinions Wanted
    Last Post: 05-04-2007, 03:24 AM
