Results 1 to 8 of 8
Thread: SketchUp Toolbar
    Houston, TX
    27
    SketchUp Toolbar
    In SU if you select a tool button (let's say the Rectangle button), and then click the Orbit button, the Rectangle button is grayed and it's Draw Menu item is checked. This indicates to me there is some shortcut (mouse action maybe?) to go back to that button but I can't figure it out.
    Or is there some other reason the button displays grayed?
    Brad
    Houston, TX
    27
    I think I found the answer. If you right click the a blank area while in orbit mode, there is an "Exit" menu item. Clicking that reverts you to your previous button.
    Easy enough.
    Sacramento, CA
    1,367
    Also, if you hit escape, it returns you to the tool you were using before in lots of cases (zoom, pan, orbit, etc)
    Jason Beam
    Sacramento, CA
    SE Minnesota
    2,526
    It's a normal thing. This is similar to using the center mouse wheel button for orbit while using some other tool. You momentarily revert away from that tool while using Orbit (or Pan or Zoom) but when you release the button, you go back to using the tool. This is handy when you need to be zoomed in or looking a certain way to start a line but need the view point changed so that you can see where the opposite end of the line will fall. Think about drawing inside a hole or perhaps between legs on a table.
    Houston, TX
    27
    Ah, escape key. Yes that does work also. As for the middle mouse button, that works great on home machine but is intermittent on laptop. Laptop is using a Microsoft Laser mouse and sometimes the middle key will put me into orbit mode sometimes not. Can’t figure out why.
    Quote Originally Posted by Brad OKeefe View Post
    ...As for the middle mouse button, that works great on home machine but is intermittent on laptop. Laptop is using a Microsoft Laser mouse and sometimes the middle key will put me into orbit mode sometimes not. Canít figure out why.
    I've got the same issues, also with a Microsoft laser mouse (corded, since wireless mice don't like my metal desk).
    Glad (and sorry) to see I'm not the only person with the problem. For me, I've just started using the "O" key to enter orbit mode, then "M" to go back to moving mode.
    SE Minnesota
    2,526
    Try assigning the middle mouse button function to Auto Scroll and see if that helps.
    Houston, TX
    27
    Quote Originally Posted by Dave Richards View Post
    No luck there, but I did find that I can custom set the button functions per application, so I assigned the "middle click" to the "Left Side" button when using SU. This works good
    Brad
  1. SketchUp Template and Toolbar Layout
    Last Post: 01-06-2015, 10:54 PM
  2. Sketchup to DXF
    By Darren Wright in forum Designs, Plans and Sketches
    Last Post: 11-24-2010, 07:24 PM
  3. DXF to SketchUp
    Last Post: 06-25-2007, 11:07 PM
  4. An Example from SKETCHUP 6
    Last Post: 01-13-2007, 12:32 AM
  5. SketchUp 6 Pro
    Last Post: 01-09-2007, 11:50 PM
