Results 1 to 6 of 6
Thread: Router Bit Needed
    Router Bit Needed
    I need a router bit to cut a cove along the edge of an inside curve, Opposite of a Bull Nose.. Along an inside curve so a regular cove bit won't work.
    My question to you all knowing knowledge based intellectual types is, What would that bit be called? I know that it is out there as I have a piece (which I must duplicate) that has obviously had one of those bits used on it.
    This is what I need to duplicate If I can find the bit, I hope I can do a better job than the other guy.... BTW 3/4" stock
    lutefisk capitol, USA
    485
    it looks to me like that was done on a shaper. i know i have seen that shape but it was a cutter that went on a 1/2 inch shank. maybe check out the cmt site?
    9,077
    I'm with Dale. Part of a multi-profile bit on a shaper would be the ticket. As to your problem, I would check some handrail and moulding bits out. Perhaps part of the profile could be used with a double pass(?).
    Tokiwadai, Japan
    2,882
    Houston, Texas
    2,323
    Quote Originally Posted by Bill Simpson View Post
    Hi Ol' Hickory ,
    I think you will do just fine but wonder if your job might be more assured of success if you made and used a pattern to guide the roller bearing of the cutter you will use?
    Shaz
    [quote=Greg Cook;81415]Bill,
    Something like the top Edge Fluting bit?
    http://www.coastaltool.com/cgi-bin/S...043+1199593356
    One from Bosch
    http://www.acetoolonline.com/Bosch-8...bos-84615m.htm
    Amana
    http://www.amanatool.com/bits-fv/54300.html
    Nice find Greg .
    [/quote]
    You can do it Bill!...S
    Please join me. Register now.
    Shaz
    Here is how
    Thanks! Edge Fluting Router Bits is what I am looking for, great links!
    As for pattern guides, yes, that is the way to go,
  1. Wi-fi router purchase advise needed
    By Tom Baugues in forum Off Topic Discussion
    Last Post: 12-10-2012, 02:01 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  3. Some router advice needed
    By Dom DiCara in forum General Woodworking Q&A
    Last Post: 08-10-2010, 05:18 PM
  4. CNC router work needed
    Last Post: 02-26-2009, 02:21 PM
  5. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
