Results 1 to 10 of 11
Thread: Rolling Mortise Jig for router table
    Nov 2007
    Poland
    267
    Good day
    So, I made the new router table and as I mentioned, I made a few "add-on's" that where my dream for long time.
    One of them is the "Rolling Mortise Jig"...it takes a few hours to build it but it's such a pleasure to work with it...I used the same method as I used for the "Rolling Tenon Jig" for the table saw.
    On the pics, you'll see only the construction and some small test...
    In the mean time I made also a router lift so it's even bigger pleasure to work
    The setting looks complicated but actually, takes a few minutes...
    Regards
    niki
ID:	16156Click image for larger version.
ID:	16157Click image for larger version.
ID:	16158Click image for larger version.
ID:	16159Click image for larger version.
ID:	16161Click image for larger version.
ID:	16162Click image for larger version.
ID:	16163Click image for larger version.
ID:	16164Click image for larger version.
    Nov 2007
    Poland
    267
ID:	16166Click image for larger version.
ID:	16167Click image for larger version.
ID:	16168Click image for larger version.
ID:	16169Click image for larger version.
ID:	16171Click image for larger version.
ID:	16172Click image for larger version.
ID:	16173Click image for larger version.
ID:	16174Click image for larger version.
    Nov 2007
    Poland
    267
ID:	16176Click image for larger version.
ID:	16177Click image for larger version.
ID:	16178Click image for larger version.
ID:	16179Click image for larger version.
ID:	16181Click image for larger version.
ID:	16182Click image for larger version.
ID:	16183Click image for larger version.
ID:	16184Click image for larger version.
    Nov 2007
    Poland
    267
ID:	16186Click image for larger version.
ID:	16187Click image for larger version.
ID:	16188Click image for larger version.
ID:	16189Click image for larger version.
ID:	16191Click image for larger version.
ID:	16192Click image for larger version.
ID:	16193Click image for larger version.
ID:	16194Click image for larger version.
    Schazam!! It is always interesting to see what you will come up with next.
    Quite extensive amount of work and thought went into this device. Thanks for the posting and pictures. I see as much work went into making the posting as well as the project.
    Ever think of making a publishing of your creations, Or at least a web site.
    Niki, it's always an education following your posts. It seems I get dozens of ideas from each one. Thanks for taking the time to document this and post the pictorial. Those last two pics prove the method works.
    Southeast Pa
    2,019
    Niki
    Just outstanding!
    Garry
    Nov 2007
    Poland
    267
    Thank you so much for your kind words
    Bill
    Yes, it take some time to build it but later when I make a mortise in 10~20 seconds...
    No, never thought about publishing
    Web site....my upper limit with computers goes up to posting pictures...but posting here is almost like having web site
    Vaughn
    I like to post many pics so one will understand better...that's the difference between "look what I did" and "look how I did"...
    I'm sure that I also picked-up some (many) ideas from books and Internet and just arranged them in different order...
    The method works like a charm and now that I added the "router lift" (next post) it's even more easier and pleasure.
    Regards
    niki
    Odessa, Tx
    1,813
    Very, very NEAT, Niki. It's a good solution, and thanks for posting it. I really enjoy seeing other people's jig solutions, even if I don't make or need that particular jig, but it keeps my mind working with Ideas that I might not have thought of that could be used in jigs that I do need and build. Keep up the good work.
    Thanks again, Niki.
    Jerry The Dinosaur Mings
    FREE RICE NOW
    Moola Invitation
    "Après moi, le déluge."
    -Louis XV
    "Arbeit Macht Frei"
    - Legend above the gates of German concentration camps.
  1. Rolling Work Table Gets Re-sized
    By glenn bradley in forum Shop Tours
    Last Post: 04-07-2013, 06:17 AM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  3. Depth When Cutting a Mortise with Router
    By gary curtis in forum General Woodworking Q&A
    Last Post: 09-09-2008, 03:56 PM
  4. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
  5. Rolling mortise jig - the test
    Last Post: 01-08-2008, 01:13 PM
