Results 1 to 7 of 7
Thread: Rolling mortise jig - the test
    Nov 2007
    Poland
    267
    Good day
    To test the mortise jig, I made a frame. I cut all the pieces to final dimensions.
    I started by cranking the router lift 1~2 turns and make a pass but I ended-up using both hands simultaneously. With the right hand I turned the router lift continuously and with the left hand, moving the jig fore and back so, each mortise took 15~20 seconds.
    The jig is not limited only to "edge mortising", by marking the required mortise locations, I can make it anywhere along the workpiece.
    Regards
    niki
ID:	16266Click image for larger version.
ID:	16267Click image for larger version.
ID:	16268Click image for larger version.
ID:	16269Click image for larger version.
ID:	16271Click image for larger version.
ID:	16272Click image for larger version.
ID:	16273Click image for larger version.
ID:	16274Click image for larger version.
    Nov 2007
    Poland
    267
ID:	16276Click image for larger version.
ID:	16277Click image for larger version.
ID:	16278Click image for larger version.
ID:	16279Click image for larger version.
ID:	16281Click image for larger version.
ID:	16282Click image for larger version.
ID:	16283Click image for larger version.
ID:	16284Click image for larger version.
    Nov 2007
    Poland
    267
ID:	16286Click image for larger version.
ID:	16287Click image for larger version.
ID:	16294Click image for larger version.
ID:	16288Click image for larger version.
ID:	16290Click image for larger version.
ID:	16291Click image for larger version.
ID:	16292Click image for larger version.
    Nike: thanks for another neat idea, but my question is what happened to your past method of posting ideas where the photos were all one after the other within the message, with your comments in between. Speaking for myself, the separate photos takes a lot away from the idea and with as many photos as in this message, clicking back and forth detracts from the beauty of the idea.
    Just my opinion.....
    Ken
    Nov 2007
    Poland
    267
    Hi Ken
    You are correct...I also don't like to "Click" and "Back" and I prefer to post the pics in their original size so you just scroll and can go up & down.....But...
    I posted a question, how the members prefer the posted pictures and I got replies that some members are still on Dial-up and it's better if I'll post the pics to the forum server...
    I don't have any problem to post them either way
    Sorry for the inconvenience
    niki
    I just built a simular fence for my router table. I used drawer slides for the smooth moving action. I have a line on the fence that I line up with the cL of the bit then adjust the fence stops 1/2 the (mortise length - bit dia) in each direction. Then on each piece I need only to mark the center of the mortise and then align that with the mark on the fence. I am working on a bedroom set for my granddaughter and am using all loose motise/tenon where that type of a joint is needed.
    Keith
    Santa Rosa, CA
    138
    Quote Originally Posted by Ken Close View Post
    Ken
    Ken,
    Just a suggestion...
    Right click on the image, choose 'Open Link in new tab' (works on Firefox and Safari, don't know about IE) for all the images then you can go thru all of them without going back and forth.
    And for Niki...
    Great idea and pics (just like all your others)!
  1. Le rolling Pin
    By Ned Bulken in forum Lathe Project Showcase
    Last Post: 10-01-2014, 08:34 PM
  2. another French rolling pin
    By Frank Fusco in forum Lathe Project Showcase
    Last Post: 08-30-2008, 11:02 PM
  3. Rolling pin finishes
    By Jonathan Shively in forum General Woodturning Q&A
    Last Post: 05-03-2008, 03:09 AM
  4. rolling pin
    Last Post: 01-11-2008, 04:24 PM
  5. Rolling Mortise Jig for router table
    Last Post: 01-06-2008, 04:11 PM
