Results 1 to 10 of 18
Thread: Timesavers Speed Sander
    N.E. Arkansas
    374
Name:	Winter shop shots 2008 009.jpg
ID:	16713Over on the classified forum I have had posted my general international drum sander and I have been asked and reminded twice by Bruce Page and Joe Mouix that you guys would like to see and hear a little about my new Timesavers "Speedsander" Review of the Timesavers "Speedsander"
    on: January 12, 2008, 05:51:38 PM Quote Modify
    One of the most difficult things that we all have to deal with is sanding, seems like that is all I got to do for days when completing a kitchen or other large project. I have been through all of the drumsanders, we all know about that and I have finally come to the conclusion that I was gonna have to spend some serious $ to get what would work better for me. About 5 years ago Timesavers came out with their "Speedsander" a widebelt machine designed for the small shop. Perfect I thought but probably not in the budget. I contacted Warren at Timesavers and he gave me the speal on the machine and I pondered my situation only to have my LOML to decide she wanted a Timewaster instead (camper) so on to saving $ again until this fall I finally decided on purchasing one of the "Speedsander".
    Large commercial shops would chuckle at this little machine weighing in at a light 1500#'s but for me it's the largest and most expensive machine that I have. The first machine arrived damaged and I had to wait more than a week to recieve another machine and fire it up. Since I had never used a widebelt sander I acutally read the manual before firing the machine up for the first time. The machine runs on a 7 1/2 hp single phase belt motor and a 1hp variable feed motor controlled by a simple dial on the front of the machine. It takes a 50 amp service to operate.
    The first pic is of the machine open to the belt access. It is an A frame machine so it is a bit tight to get the belts on and off the machine however it is very doable.
Name:	Winter shop shots 2008 001.jpg
    The second shot is just a wider perspective of the same side of the machine showing the location of the height adjustment handwheel which is very easy to operate. I expected something like a drum sander but this is one smooth operating handwheel. Each revolution of the wheel will move the table precisely .020
Name:	Winter shop shots 2008 002.jpg
    This pic is of the operators side of the machine showing the controls and the wixey scale on the left. The red bar across the width of the sander right above the feed belt is the emergency shutoff and also prevents any possibility of double feeding. It's a sensitive little raskal too, I have set it off accidentally 2-3 times already. When it is activated the machine comes to a halt within 2-3 seconds, it has an electronic brake. The red button on the left serves as the off switch and the reset once the brake has been activated.Click image for larger version.
Name:	Winter shop shots 2008 003.jpg
    This is the backside of the machine. On the left is the air supply valve and another emergency stop button. The motor on the left is the feed belt motor.
Name:	Winter shop shots 2008 004.jpg
    Inside the machine the bottom two rollers can be seen, the one on the right is the contact drum that applies the paper to the material when you don't have the platten in place. The platten is right in the middle between the drums and is easily removed by just sliding it out of place. The head lock device is what is seen just to the right of my hand, this has to be removed to take out or replace a belt. It is easily attached and removed.
Name:	Winter shop shots 2008 005.jpg
    In this shot my hand is on the air valve that applies the pressure to the tracking mechanism that oscilates the belt side to side during a sanding operation. The belt moves side to side about 1 1/4" or so.
Name:	Winter shop shots 2008 006.jpg
    This is what it looks like to slide a belt into the machine. There are a few obstacles to manuver around but the belt can be changed in about a minute.
Name:	Winter shop shots 2008 007.jpg
    Here is how I'm storing belts now but I need to get a proper rack soon. Eighty grit used belt on right and 120 on left.
Name:	Winter shop shots 2008 008.jpg
    A shot of the wixey ( not a wixey brand but nonetheless it works) device, I haven't gotten to appreciate it much yet but likely will.
    The platten used with 120 grit belt. It is the contact surface when in use and provides a bit more "cushion" than the contact drum.
Name:	Winter shop shots 2008 014.jpg
    I once heard that cats and women will do darn well what they please and that men and dogs would do well to accept it and just go on.
    N.E. Arkansas
    374
Name:	Winter shop shots 2008 011.jpg
    Glued up maple panel before sanding
Name:	Winter shop shots 2008 012.jpg
    Glued up maple panel after several passes with the 80 grit, I removed .028 from the thickness
Name:	Winter shop shots 2008 013.jpg
    I took this shot to show the flatness of the panel, sure is better than any drum sander I ever owned but then it should be now.
Name:	Winter shop shots 2008 010.jpg
    This is a shot of the platen that is used instead of the contract drum when sanding with a finishing belt. I'm using 120 grit for a finishing belt and am having tremendous results. The platen simply slides in the machine without any sort of a fastener. It is covered with a graphite fabric that will have to be replaced somewhere down the road quite a ways
    This is just a shot of the finished panel after sanding with the platen and 120 grit paper. I just laid the caliper there to give it some sort of scale
Name:	Winter shop shots 2008 015.jpg
    Here is another shot of the same panel laying in a little different light. Again sanded with 120 paper.Click image for larger version.
Name:	Winter shop shots 2008 016.jpg
    A couple of oak doors finished with the sander stained minwax provential and shot with satin lacquer. Click image for larger version.
Name:	Winter shop shots 2008 017.jpg
    This door does not have any lacquer on it, just stain.Click image for larger version.
Name:	Winter shop shots 2008 018.jpg
    Austin, Texas
    1,448
    Jim, had you looked at any of the competing wide belt sanders?
    Did you have to beef up your dust collection to run the wide belt? I assume you already had shop compressed air.
    Charlie Plesums, Austin Texas
    Albuquerque, New Mexico
    1,099
    Dang, retirement must be good, you went with the Cadillac of widebelts!
    You mention that the red emergency shutoff prevents any possibility of double feeding. What is double feeding?
    I guess the real question is how does it sand and how much better than a drum sander?
    Thanks for the pics, they were worth the wait.
    friend...if you have one."
    one."
    N.E. Arkansas
    374
    Quote Originally Posted by Charlie Plesums View Post
    Well the only one I looked at was the Grizzly and this one just suited my needs much better and it was more well made for the buck. I haven't had very good luck with Grizzly tools either so they lost my confidence a good while back.
    I didn't do anything to the DC except hook it up. The sander only requires 650CFM to operate the dust collection. Their setup is really slick and picks up the dust at the point where it is made.
    N.E. Arkansas
    374
    Quote Originally Posted by Bruce Page View Post
    Well it's just Cadillacs smaller version, I'll assure you it is not one of the old fashioned Timesavers but is the Speedsander sold by Timesavers.
    Double feeding is the accidental entry of two pieces of material, one on top of the other.
    The answer to your question about it's performance is in the pics of the panels. With a drum sander I always got streaks produced by residues left on the paper. There is no residue build up on the belt at least not in a pattern like a regular drum will produce. The belt oscillates about 1 1/4" from side to side to produce a great surface. Even on cross grained parts like the oak door styles in the pic. Very little sanding with a random orbit has to be used to get the crossgrain marks out, probably less than a minute per door. How much better than a drum sander, 300-400 percent easily, it will truly pay for itself in very little time in labor saved hand sanding doors and faceframes.
    1,099
    Thanks Jim. Those panels are sweet.
    one."
    Looks great Bony, so I guess that means you will be able to pump out even more doors
    Man, you don't just run down to the Borg and pick up an extension cord for a 50 amp machine, huh?
    Looks like a great tool, Jim, and it sounds like it's gonna make you some money. Congrats.
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    Hi Jim, Congratulations a very impressive machine, How are the costs for the belts and how long do they last? Is there a cleaning method for them?
  1. Need for speed
    Last Post: 03-26-2011, 09:31 PM
  2. slowing down the speed???
    Last Post: 06-15-2010, 08:13 PM
  3. DSL Speed
    By Bartee Lamar in forum Off Topic Discussion
    Last Post: 10-19-2009, 01:08 AM
  4. Belt Sander or Orbital Sander
    By Dawson Mossman in forum New Tools
    Last Post: 09-18-2009, 01:03 AM
  5. Belt Sander vs a Drum (thickness) Sander
    By Ken Close in forum New Tools
    Last Post: 11-26-2007, 01:36 PM
