Results 1 to 9 of 9
Thread: New Infinity Blade...
    Tokiwadai, Japan
    2,882
    Just got an email on this new Infinity Super General, 40T crosscut and rip blade... Apparently won Top Tool from Wood Magazine.
    http://www.infinitytools.com/products.asp?dept=1413
    Anyone tried one of these?
    Dunno Greg, but I am in the market for a new blade for my TS, so if you get one, report back please
    Rochester
    846
    Hi Greg - I got one last October and gave it a whirl. First impression is very favorable...it leaves an edge that's shiny enough that I can actually differentiate between it and other top 40 or 50 tooth GP/combo blades, which is really saying something. It's a full kerf so it doesn't rip thick stock on my saw as easily as I'd like, but it's fine for most stock and will be a breeze for a 3hp cabinet saw. The teeth are humongous! It's geometry is much like the new Freud Fusion but the teeth are bigger....30 bevel, steep hook angle, and a double side grind with a very tight side clearance. It's really nice in ply and sheetgoods too. It's a bit fussier than some of the other top notch blades...burns a bit easier, but once you dial it in, it's impressive. I'll get a longer term impression in the spring.
    Got Wood?
    Punta Gorda, Florida
    902
    If anyone knows Scott knows. I do not have that blade but have two other Infinity blades and I cannot see how it gets any better.
    Tokiwadai, Japan
    2,882
    Thanks, Scott... Like Alan said, "you da man" when it comes to TS saw blades.
    I guess I should have clarified myself...I'm not in the market for another blade myself (Happy now with my WWII and Tenryu Gold Medal). I just wanted to let others see and comment on what looks like a solid competitor to the Forrest WWII...the often mentioned "standard" in the TS blade world.
    Thanks.
  6. Quote Originally Posted by scott spencer View Post
    I'll be interested in how your blade performs after being sharpened by face grinding the way Infinity recommends on their website. The flats formed by the double angle side grind on the Premier Fusion P410 are the reason it burnishes the cut edge to a glass smooth finish and we recommend top grinding to retain this feature. They seem to think you are better off without the flats on the sides of the teeth so I don't understand why they even copied the design.
    Rochester
    846
    You probably can't get away with many face grinds or the double angle will be gone.... (more like maybe one or two). Can good sharpeners duplicate the double grind at some point, or is it too complex?
    Got Wood?
  8. Quote Originally Posted by scott spencer View Post
    A sharpener could possibly put the primary angles back on the tips but I doubt there wouldn't be enough side clearance left to prevent burning.
    Nov 2007
    Glendale, AZ
    5
    Quote Originally Posted by Charles McCracken View Post
    I have to agree with Charles. One way or another, whether just topping or just facing or doing the more common a little of both, blades with the double side grind end their usefull life with about 1/2 the carbide still there. They can still be made to cut but the planing feature starts going away and saw marks start to show.
    Scott's Sharpening Service
    Glendale, AZ
  1. New Lock miter bit jig from Infinity
    By Alan Bienlein in forum General Woodworking Q&A
    Last Post: 04-14-2014, 08:24 PM
  2. the infinity chair
    By Rich Soby in forum Off Topic Discussion
    Last Post: 07-12-2011, 11:41 AM
  3. Infinity's at it again....
    By Jim O'Dell in forum Hot Deals
    Last Post: 04-17-2008, 02:13 AM
  4. Infinity deal!
    Last Post: 12-28-2007, 01:12 AM
  5. Infinity deals thru 11/25
    By scott spencer in forum Hot Deals
    Last Post: 11-24-2007, 11:46 PM
