Results 1 to 10 of 15
Thread: Bandsaw ?'s
    Nov 2007
    Gilbert, AZ
    25
    Bandsaw ?'s
    I have a Grizzly G0580, 14" 3/4hp and it's time for a new blade. I am thinking of putting the riser block on so I figure might as well buy the longer bands and do the whole thing at once.
    My question is, Do you think the 3/4hp will be enough when I put the 105" x1/2" 3tpi band on? I use it mostly rounding bowl blanks and the "quick cuts". What will be the difference in operation or finish or ? in a 2 tpi or 3 tpi band? I plan on using Timberwolf blades.
    Kevin
    >>Enter witty saying here<<
    I'm sure there are other experiences but on my 1/3HP C-man 12", I ran a 2-3 TPI 1/2" Timberwolf and got good results considering the saw. Resaw height was 6" and as I approached that the saw would bog down if I tried to go more than about 1/2" per second.
    535
    Hi Kevin,
    While I'm no bandsaw expert, I believe the HP question has more to do with cut height than blade width or tpi - though perhaps that's what you're asking in a way. You'll have no trouble running a 1/2" - 3tpi blade with 3/4 HP, but you might find that a 6" thick cut makes it grunt a lot. I think most tall saws, both riser and stock, tend to use 1 to 1 1/2 HP minimum and up to 3 HP on the stock 16" saws.
    Sep 2007
    St. Louis, MO
    583
    Older saws with riser blocks set up for resaw often had 3/4hp or smaller motors on them. You should be fine if you slow your feed rate down as your cuts get taller and in harder wood. It's not a "commercial" setup, but you probably don't need to feed a ton of lineal feet of resawing through the machine each day to make the thing earn its keep. For a hobbyist, 3/4 hp should be fine. Force feeding thick cuts through this machine will lead to other problems as well, not just undo strain on the motor. Take it easy - let the machine do it's work and you should be fine.
    I've got an old Crescent 20" saw with a 1" 3tpi blade and a 1hp motor. It will resaw up to just a hair under 12". For most tasks it's fine, but the taller cuts in harder wood do require me to slow down the feed rate a bit - pay more attention to what i'm doing. The cut quality doesn't suffer, i'm just standing at the saw a few seconds longer for each cut - big deal.
    Before i got the 20" saw, i was occassionally resawing up to 8" tall with a 1/2" 4tpi blade and a 1/2 hp motor on a smaller, off brand saw. That saw was never meant to resaw, but if i didn't force things, it worked fine. I didn't upgrade my saw because of any dissatisfaction, the Crescent fell in my lap - free for the taking.
    This is my hobby, not my job. I enjoy my time in the shop. I try to speed up or avoid tasks i don't like (such as sanding), but sawing isn't one of them.
    If it were me (and i know it's not) i'd go with the riser kit if i thought i'd use it. Then, if you really get frustrated with the motor, you can always upgrade that as well at a later date.
    I guess the other option would be to spend no effort upgrading your saw and look into bigger, more powerful machines, but that seems like a stretch for someone who just needs a new blade.
    If you're wearing out blades, that's good - you're getting your money's worth from your saw.
    have fun with it.
    Paul Hubbman
    Quote Originally Posted by Paul Hubbman View Post
    ............If it were me (and i know it's not) i'd go with the riser kit if i thought i'd use it. Then, if you really get frustrated with the motor, you can always upgrade that as well at a later date. ...............
    Paul Hubbman
    I think this is excellent advice.
    The Heart of Dixie
    4,268
    I have the same or similar saw. Never cared to memorize all these numbers. I have the riser and have cut some big stuff with a Timberwolf blade. Mine is more like 6 teeth I think. But it does fine. Never had a problem. With harder woods it's just going to take some more time but I don't think you will have any problems. Just work smart.
    Custom built boats and Kits
    Nov 2007
    Gilbert, AZ
    25
    Good advice guys, Thanks.
    I just didn't want to hear, that it would be a pig and wouldn't even cut the grass. I tend to be pretty easy on equipment so it sounds like I should be fine. I really don't do any resawing mostly just turning stuff but but a lot of my blanks don't quite fit and I want to add a table that will take up a little height also.
    30,017
    Kevin, I think the 3/4hp should be fine, especially if you're just rounding out turning blanks. As far as blade selection, I just called the folks at Suffolk Machinery and told them I wanted something for cutting green bowl blanks. They set me up with the right blade -- I don't even remember the details about it.
    University Place, WA
    101
    I think if it was me and only using it for turning blanks I would go with a 3/8 3 tpi blade, less blade for the curves = less resistance.
    PS. I will add, I keep a 1/2 inch on my Jet 1 hp with riser and there is no way I could cut a 10 inch thick blank following a 12 inch circle, I just cut the corners as needed till it is close to round.
    11,832
    My G0555 has a 1 hp motor. I have cut quite a bit of Osage Orange at the 6" max using a 3/4"X3tpi Timberwolf blade. It cut well but I could have had problems if I forced. Patience was required. Personally, I would not add the riser block. I believe a
    14" bandsaw is designed to do what a 14" bandsaw is intended to do and adding the riser will stress beyond that intention. BTW, my next resaw blade will be a 4 tpi as cutting thinner pieces, like 1" caused catches. Not good.
  1. Bandsaw Box
    By Bob Gibson in forum Flatwork Project Showcase
    Last Post: 03-25-2014, 07:52 PM
  2. bandsaw box
    Last Post: 06-29-2009, 01:06 PM
  3. BIG bandsaw
    By Dale Johnson in forum Old Iron
    Last Post: 05-17-2009, 03:28 PM
  4. My new Bandsaw....
    By Ned Bulken in forum New Tools
    Last Post: 04-13-2008, 05:14 PM
  5. Need a bandsaw bad!!!!
    By Chuck Hanger in forum New Tools
    Last Post: 12-12-2007, 01:05 PM
