for an old vice,, the part that holds the handle the approx 1" T fitin that the handle goes threw can i get just that part somewhere?
Maybe buy a cheap junk vise and take the part off. You could go to http://owwm.comand list under wanted items or go see a black smith and have one made.
Larry can you get a picture of it, or describe what broke?
From the little that has been described it sounds like a bit of welding will get it back in shape. Most likely its cast iron, but I have had good luck welding cast iron. One trick I have used is to tig weld it, but rather then using cast iron tig wire, which I have NOT had good luck with, is to use stainless steel filler wire. The nickel in it seems to bond better to the cast iron.
Of course you cannot use this trick on any part that is going to polished as the dissimilar metals will show, but I doubt polishing a vice is likely.
well travis i agree that welding works when there is both parts but see i dont have the rest of it..and nickel is by all means the ticket for cast iron. at least with the little welding i have done. i rethought this threw a bit and might be able to get a 1" tee and take out the threads and make it work.. so thanks for the input folks..
If you need help Larry, and the part is small enough, you can ship it to me and I can probably fix it. Considering my occupation, I am sure we can get the part fixed one way or the other. PM me if you need some help. No bother at all.
