Results 1 to 10 of 14
Thread: Framing nailer into masonry
    Hey All, I just bought a framing nailer, a Bostitch F28WW. It says it can nail wood to masonry. I'm getting ready to put walls in my basement. Can I nail a 2x4 to the floor with this thing? If so, what nails to I buy. I emailed Stanley/Bostitch and they never replied. I downloaded the Bostitch nails that were available but none came right out and said they were for this purpose.
    Kevin
    Tokiwadai, Japan
    2,882
    I would think you might be able to nail a 2 x 4 into a concrete block wall or home walls that are covered with plaster, but I wouldn't think they mean it will nail into solid concrete floors....
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    Kevin Pre drill with a hammer drill and a 3/16 th bit with two pieces of tie wire and a common 3 1/2 nail. That will hold a 2x4 to concrete don't try using an air nailer to do it you will just spall the concrete. They are not designed to do things like that no matter what they might say.
    You can buy one of those Hammer driven nailers for like 30 bucks. I call it a Hilti Gun, but its not as fancy as the name brad. At least mine does not have a trigger and all that. You just buy the different powder loads, the length of nail and you are good to go. Hit it with a hammer and the shell goes off and drives a special HARDENED nail through the board and into the concrete.
    I would think using anything other then a Hilti-Gun type fastener is asking for trouble.
    15,806
    I'd not try it, you might end up hurting the gun, or worse yourself.
    Drill and anchor, and or there are some liquid nails type of stuff that work well with concrete and 2x4s.
    After a bit more thought, I think you might be able to get away with it as long as the concrete you were driving a nail into was fairly fresh. By fresh I mean no more than a week old or so. I could see that working quite well as concrete sets up quick in the first 24 hours, but does not really get hard for 28 days, and then still hardens more over the next 20 years or so.
    Anything over a week old though and I would try a Hilti Gun.
    Inside the Beltway
    2,666
    Kevin,
    Do a test. I have one of those hilti guns, but all the concrete around here is 45 years old. Didn't want to mess up the basement slab, so I went out to the shop, put a 2x4 on the floor, and started shooting. The concrete is simply too hard. It either cratered, shattering like glass hit with a bb, or the hardened nail bent. Hopeless.
    You're way better off with a hammer drill and anchors. I even use those for concrete block. The gun is just way too violent for indoor work, IMHO
    Bill
    (ps... the gun may not work, but it *is* fun... The boys loved watching the test. Much amusement was had by all, even if I didn't let them shoot it...
    Nanaimo B.C. Canada
    131
    Lightbulb
    Hi Kevin, I see what you mean about the lack of information from Bostitch...
    The website for your F28WW says that it can be used for "wood to masonry" but it doesn't mention anything else about it...
    The manual is not much use either...
    I would try a test as Bill suggested... I would try using these nails, the biggest diameter available for this gun. I would also crank the psi on your compressor to about 120.
    If it doesn't work then I would just use a Hilti or Ramset powder actuated concrete fastening system as suggested.
    I have seen other air powered concrete fasteners such as this one by Max, but it's a rather expensive unit and runs off of a high pressure compressor.
    Good luck with your project
    Cheers! - Jim
    Charlotte, NC
    1,487
    My bet is they are saying masonry as in morter joints or concrete block. I would not try it into a slab floor. Get yourself a powder actuated nailer like Ramset. Lowes and HD booth carry them and they work nicely.
    Tokiwadai, Japan
    2,882
    Kevin,
    Find someplace like this....http://www.cardwellhomecenter.com/toolrental.html
    Good luck! Post some pics of your project.
  1. Replies: 0
    Last Post: 04-16-2012, 01:43 PM
  2. Brad Nailer and Finish Nailer problems
    By Doug DeVore in forum General Woodworking Q&A
    Last Post: 11-09-2010, 04:23 PM
  3. Which framing nailer?
    By Paul Downes in forum Carpentry and Construction
    Last Post: 07-31-2010, 01:21 AM
  4. Replies: 1
  5. FS: Porter Cable FC350A - Clipped Head Framing Nailer
    By Keith Starosta in forum Old Ads
    Last Post: 04-11-2008, 03:08 PM
