Bart, That's almost the same drawer config that I was thinking about for mine, except the larger drawer on the left side. For just above the center drawer, I was thinking of putting in a shelf and a 4 plex electrical plug above that. I'm wondering if i need the big drawer. I don't usually have more than a couple of blades around, so thinking about just three smaller drawers on each side.
If you want it on the left that works. Question what blades or Dado or molding heads are you going to have in the future? Make sure you have room to grow. In the drawer below the right section just slides in, also grippers need a larger drawer to store them in hint hint!!!!
The center above the drawer is a dust chamber & has a sloped bottom high in the front & low in the back with a DC hook up down low on the back. There is a slide gate on the right end of the cabinet with stops on both ends of the gate & a dowel extending the handle right close to the front. The DC runs from left to right through the blast gate.
