Results 1 to 8 of 8
Thread: Wiring up a SteelCity 18" BS
    Qualicum Beach, Vancouver Island
    103
    OK, so I have a new bandsaw and need to connect it to a source of high octane electrons. The 18" BS is intended for 220v so I want to connect it to my pre-existing 220v lead that is currently in use for my MM combo. That lead has a NEMA L6-30 socket on the end, which has found connections. The BS has a rather odd looking three pin plug of a sort previously unknown to me
    Sort like this
    What I need to know is how I should connect the wires from the BS to a suitable L6-30 plug.
    tim
    Laser printers on Stun! Prepare to fire!
    So do I type something witty here?
    I'm a little confused; is the typo "has found connections" supposed to read "has four connections"? The NEMA L6-30 spec
    is for a 2 pole 3 wire device. The pin with the right angle jog in it is your ground. The other two are your hot leads.
    Again I may be guessing wrong but I think the pin pattern your showing is this NEMA 6-15 (?)
    which is a 220v 15a.
    My 2HP Griz runs this NEMA 6-20 (looks like a 5-20 except for voltage rating, 220v 20a):
    Tokiwadai, Japan
    2,882
    Tim,
    Ditto what glenn said...
    Is the plug/socket on your cable to the MM similar to this?
    Attachment 16979
    And the plug on your SCT BS like this?
    Attachment 16978
    I would probably change the plug on the BS to match the locking one.
    103
    Oh how embarrassing. Not only a stupid typo but I actually made myself look like a botanist[1].
    Yes, it's an L6-30 with THREE pins, one bent L-shaped. And yes the one currently on the BS is like those pictured. So if the L-pin is ground on the L6 and the middle pin on the current plug then it should be simple to rewire.
    tim
    [1]Botanists are well known for being able only to count up to 3. As in "one, two, three, lots".
    Tokiwadai, Japan
    2,882
    Tim....
    Not to worry, just let us know how you do on the "re-wire" and how the BS works for ya!
    103
    Well it turned out no more difficult than fitting a UK 240v plug. Everything works, the BS whirrs to life smoothly and appears to cut with no discernable drift, no tracking problem, nada. Excellent!
    Tokiwadai, Japan
    2,882
    Congrats, Tim.
    But....pics are a requirement here.....
    No, not just the plug.....that cool Steel City BS!
    103
    Quote Originally Posted by Greg Cook View Post
    OK already! Here's a couple of shots from my first quick resaw this afternoon; I needed to reduce some VG fir from 6/4 to 4/4 for a base moulding on a little dovetail box/faceframe bookcase I'm making. Hand cut dovetails to match the larger case I made a month ago, painted back panel ditto, etc etc.
    Despite just using the provided blade (rather too many tpi for a resaw) it did a fine job, no wandering not explainable as my own fault for dithering, and it cleaned up with a couple of passes under the planer.
    So far so good I think. Quite an impressive saw for $1500 (including a mobile base the dealer threw in gratis).
  1. 220 V wiring question
    By Allen Bryant in forum Carpentry and Construction
    Last Post: 09-24-2014, 06:41 PM
  2. Wiring question!
    By Barry Stratton in forum Carpentry and Construction
    Last Post: 06-23-2014, 12:56 AM
  3. Wiring for my new DC.
    By John Pollman in forum Off Topic Discussion
    Last Post: 04-24-2013, 01:58 AM
  4. Wiring your shop for 220
    By Jim DeLaney in forum Off Topic Discussion
    Last Post: 02-26-2011, 01:08 AM
