Results 1 to 5 of 5
Thread: sander? a few questions
    17,472
    first of all those of you who use air sanders, whats your prefernce, pad size,orbit size H&L,PSA,hard or soft pad?
    now as for a 6" sander electric with intension of using it as a buffer as well. am looking at the bosch 1250 for this, but would like your input, should i get a hard pad, would psa be better what about the pad for buffing? thanks for the info.
    17,472
    bump
    several veiws no opinions
    5" psa medium 3-m is my favorite.
    5,321
    Festool 5" Rotax - hook-n-loop.
    I like it because of its 'dual action.' It can be a good finish sander, and still be nearly as agressive (but smoother) as a disc sander.
    Kinda pricey, though. I think I paid $340, but it's gone up a couple times since then.
    17,472
    thanks tod ,,if i member corectly you dont use vacume on your sander? and to jim the bosch i mentioned has the feature you mentioned on your festool. do you use yours for buffing out at all? have read that its good way to get a satinny feel on a finish. either hand or by machine. if any one uses a sander to buff what pad would you suggest? thaks fo rthe input
  1. questions about jet 10-20 drum sander
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 09-28-2013, 04:18 PM
  2. Mortiser/Drum Sander Questions
    By Sayer Fancher in forum New Tools
    Last Post: 12-16-2012, 01:52 PM
  3. Spindle sander questions
    By larry merlau in forum New Tools
    Last Post: 03-28-2009, 05:40 PM
  4. Belt Sander vs a Drum (thickness) Sander
    By Ken Close in forum New Tools
    Last Post: 11-26-2007, 01:36 PM
  5. P-C Belt Sander Questions
    By Vaughn McMillan in forum New Tools
    Last Post: 12-12-2006, 04:09 PM
