Results 1 to 9 of 9
Thread: Pen blank size?
    Pen blank size?
    Hey pen turners,
    I'm cutting up a bunch of small chunks of wood I have lying around into pen blanks to swap and sell (don't turn pens myself) What is the standard size for a pen blank, and what is the smallest usable size? Looks like most on ebay are 3/4 x 3/4 x 5. Also, is some checking acceptable? I have a lot of high figured/burl iron wood, but some is smaller than stated above and/or has some checking. Pen gurus... Help me out! Cheers, Barry
    Goodland, Kansas
    4,834
    Checking is ok if you know you will be able to turn it out. Most times I have not had good luck doing that because you can't see the hairline cracks that sometimes go all the way thru. Since I am glueing a brass tube in them I don't like wasting time with cracks or checking. Most of the blanks I cut are at least 3/4 X 3/4 X 5 1/2. If I am doing a slimline I have some that are 1/2" sqaure and will be ok. For bigger pens such as Cigars or El Grandes I use the bigger blanks. Hopefully someone else will get in here.
    Bernie W.
    North West Indiana
    6,098
    Bernie has posted the answer I agree to.
    11,832
    Yes, the size you state is considered 'standard'. As for checking, I make judgement calls on those. Sometimes I'll add for free to orders. Customers don't like getting stuff that looks like a discard. If it is still good for a pen but just looks lousy I'll keep and make a pen for myself. For larger style pens, going 7/8"X7/8" or even 1" is desirable. Many penturners state they can drill a 3/4" blank OK for large pens. Yes, it can be done and I have done it. But, there is a higher risk of blow out. With fine woods, especially burls, I'll cut 1" for that margin of safety and consider that, in the long run, the waste is less.
    BTW, that burl ironwood sound delicious. You might want to consider doing that in 1" blanks as it would look very elegant in a larger style pen like a Jr. Gent or full sized Gent.
    San Antonio, Texas
    765
    Barry, I concur with all answers thus far. And I'm sure you'll find takers for any size you cut. Concerning the "smaller" stuff, how much smaller? In length, or width? For checked blanks, I'm like Frank. If I can turn the check out, I'll keep it for myself and not trade, or sell it. If I can't turn the check out, I'll cut the blank up for a segmented pen. If the blank has voids, inclusions, etc., I'll fill these with colored resin. So if you have any of this "worthless" stuff in burls or figured wood, let me know so I can tell you where to send it.
    EDIT: Below is an example of some Buckeye burl that I filled with resin.
    Attached Thumbnails Attached Thumbnails churchillUGrb_worthless_buckeyeburl.jpg
    Drums, PA
    292
    For my own use, cut my blank 5" to 5-1/2" long
    For sale or trade I'd cut them 6" long
    Depending on how the stock is dimensioned to begin with, Most of the time I'll cut them 3/4" x 3/4"
    Thanks for the feedback guys. I ended up with a few that were slightly less than 3/4 and some as short as 4 1/2 but I only kept the good looking stuff in that small of size. I just couldn't throw it away. While I got you guys on the subject, what is a good blank size for bottle stoppers? Barry
    San Antonio, Texas
    765
    Barry, for stoppers I prefer a minimum size of 1.5" sq x 2" long.
    Oh, and don't worry about the short blanks. I keep short ones for Polaris style, Executive and Sierra pens.
    11,832
    Quote Originally Posted by Billy Burt View Post
    Yeppers. Wat Billy said.
  1. Blank Cut From ............
    Last Post: 06-04-2014, 02:40 PM
  2. $40 Canadian Pen Blank
    Last Post: 06-28-2010, 02:32 PM
  3. Pen Blank Swap
    By Ted Tailor in forum Lathe Project Showcase
    Last Post: 06-27-2010, 06:43 PM
  4. Pen blank swap?
    By Paul Downes in forum Giveaways, Contests, and Swaps
    Last Post: 05-30-2010, 03:19 AM
  5. From Blank to Sedona
    Last Post: 05-15-2009, 02:43 AM
