Results 1 to 6 of 6
Thread: Return to service . . .
    El Paso, TX
    146
    Broken nose re-shaped, entierly stripped and re-japaned ( asphaultum, of course ! ), polished and waxed. Even more fun to use when its look'n good ! Yes, yes, feel'n pleased with myself !
    17,475
    is that a 190 0R a 192?
    El Paso, TX
    146
    Sorry, # 289 . . .
    still prowling for fence and depth stop though !
    Alan DuBoff is offline Former Member (by the member's request)
    711
    Central NY State
    3,374
    Looks great!
    Would you share your japanning recipe and technique please?
    Ken
    El Paso, TX
    146
    You bet !
    Over the years, people have asked me for the best way to use my japanning, and I have been responding with the basic “textbook” version. Now, a master refinisher has shared with me what he does, and I am passing along his wisdom. His method is described below. This is not a recommendation—the official method is to air dry, but that does not impart a hard finish.
    WAG Japanning, LLC
    Bill Gustafson
    oldtools@taconic.net
    518.392.2845
    BLACK JAPANNING CURING SCHEDULE
    Set Up
    Set the items on a cookie sheet that will not be used for cookies—ever. That makes it very easy to transfer the parts to the oven.
    Some parts may need additional support. With a bit of thought, various jigs can be made using kiln dried hard wood and nails and wire—no resinous wood at all.
    Applying Black Japanning
    Apply japanning in smooth, even strokes, being attentive to cover all necessary surfaces. Don’t be overly concerned about getting it where it shouldn’t be.*
    On occasion it may be necessary to coat a surface while it is in a horizontal position and to allow the japanning to set before proceeding to other surfaces.*
    When the part is covered, set it aside for several hours at room temperature (70 - 80F).
    This will allow the japanning to flow and smooth out. Any cooler and it won’t flow properly;
    very much warmer and it will set before flowing.*
    After setting, examine each part and carefully touch up any areas that may need it.**The japanning is very soft, so be careful not to touch painted surfaces.*If the touch up was very minor, proceed to curing; otherwise let it set.
    Curing The Japanning
    If you intend to do this in the kitchen oven, it is best that your significant other is not at home as they seem to take offense to the odor even when the exhaust fan is on.
    1. Place the cookie tray with parts on a middle rack in the oven.
    Set the oven to about 125F.
    Cure one to two hours at this setting—longer times won’t hurt; less time will.
    2. Raise temperature to about 225F.
    Cure one to two hours at this setting.
    3. Remove parts from oven and allow to cool.
    At this point the japanning is quite firm but can be removed with lacquer thinner.
    Using Exacto knives or single a edge razor blade, shave excess japanning from edges, etc.
    Q-tips dipped in lacquer thinner will remove all trace of japanning where desired. Any grossly uneven areas of japanning can be shaved or scraped carefully, and even smoothed out with a bit of thinner. Small touch ups are also possible at this time.
    This is the point where you want to be certain you are satisfied with the appearance.
    Any dull areas resulting from scraping will become glossy with further curing.
    4. Return parts to oven, and set temperature to 325F.
    5. Raise temperature to about 425F.
    *** Cure one to two hours at this setting.
    6. Remove parts from oven. WATCH OUT, —this stuff is hot.
    You could just turn the oven off and let things cool off; sometimes letting it set overnight in the oven is just peachy.*
    More Info of Interest
    When using a gas oven, there is considerable moisture given off from the burning gas;
    this will actually aid in producing a nice brown patina on uncoated surfaces.*
    The cure times are approximate. A longer time at any given temperature will only make things better. If the curing time at any step is too short, out-gassing will cause bubbles, and pits
    will occur.
    This is a bit of an art, so results can vary.
    CAUTION!
    When working with paints, solvents, and heat there is always some risk involved,
    so I am not recommending that you try any of the above, and I ain’t liable if you do. The above is just what I do to get a historic, accurate finish.
    I’m what they call judgment proof anyhow.
    Jack Zimmerman**
    395 Flat Rock Road
    Port Matilda, PA* 16870
    814-692-7691
    jack3zim@adelphia.net
    Last edited by Nancy Laird; 01-30-2008 at 10:34 PM. Reason: Remove profanity and allusions to profanity
  1. Return of the Chestnut
    By Ted Calver in forum Off Topic Discussion
    Last Post: 11-24-2014, 02:04 PM
  2. Not a bad return
    Last Post: 07-10-2014, 01:10 AM
  3. Return and Re-introduction
    By Larry Fredric in forum Welcome and Introductions
    Last Post: 03-26-2010, 10:04 AM
  4. investment bonanza return - NOT
    Last Post: 04-20-2009, 07:04 PM
  5. Return clients are always nice to have
    By Marty Walsh in forum Lathe Project Showcase
    Last Post: 01-29-2008, 10:59 AM
