Results 1 to 10 of 14
Thread: E.C. Atkins & Co. - 'Circular' Saw blade
    Recently I came across a pair of 'brand new' E.C. Atkins saw blades. They are about 11" across, but they are almost square. There are 4 teeth on the corners, and 4 teeth that are on a smaller diameter than the other 4. They are all carbide tipped. The major teeth have chamfers on them, the small teeth do not.
    I dont have pictures that I can 'fit' as an attachment. I can email someone pictures if they might know something.
    Thanks.
    Tokiwadai, Japan
    2,882
    Mike,
    First, welcome to the forum....
    If you email the pics to me, I'll adjust them and post for you. My email addy is in my profile.
    Greg
    Hi Mike, welcome to the Family!
    Sounds like one of those blades they had a while back so you could cut curves with your circular saw....
    Look forward to the pics
    Alan DuBoff is offline Former Member (by the member's request)
    711
    I can see this saw blade being used in like ripping operations. Its hard to picture...and this is 100% speculation, but I can see a tablesaw being equipped with these blades. The square blade would rotate with the four corners using the teeth to cut through the wood and then the middle of the blade "sweeping" out the swarf (sawdust). That would certainly explain why the teeth on the corners are shaped for a shearing cut, and the middle ones are rather straight to clean out the kerf better.
    The thing to keep in mind is, these old tablesaws (or buzz saws as they were called) were beefy units with lots of cast iron for mass. They could easily handle something out of round and still not vibrate like a saw that was made today would. They also had flat leather belts so if something was hit to hard, the belt would slip long before anything broke...and speeds on these old flat belted monsters could be changed with a simple move of the cone pulleys. You could easily speed up or slow down the saw to be able to saw whatever it is you wanted...or in this case, mount whatever sawblade you wanted on it...even if it was squarish.
    Again this is all just speculation
    13,462
    Welcome to the family Mike.
    I dont know what kind of arbors old table/buzzsaws had, but the 'arbors' on these are more like hubs: 4" bore with 8 bolts, bolt circle is about 0.060" thicker than the rest of the blade but only on one side. Thats why I thought it was some kinda dado, or maybe a gang saw. Pics should be on the way. Thanks so far for the info though everyone.
    Mike
    Tokiwadai, Japan
    2,882
    Here are Mike's pics of the blades...
    Attachment 17343
    Attachment 17344
    Attachment 17345
    11,833
    I recall those tablesaw blades that could cut circles were sorta triangular. Weird looking things. Of course this 'square' blade is equally weird and very scary. Hang on wall. Conversation piece.
    The Heart of Dixie
    4,268
    Probably a machine/job specific tool used in some industrial setting.
    Custom built boats and Kits
  1. need a new circular saw
    By Paul Downes in forum General Woodworking Q&A
    Last Post: 11-28-2013, 01:53 AM
  2. HF Circular Blade Sharpener
    Last Post: 10-22-2011, 02:12 PM
  3. Blade selection - circular
    By Chris Hatfield in forum General Woodworking Q&A
    Last Post: 02-05-2011, 08:13 PM
  4. As The Saw Blade Turns (updated blade charts)
    By scott spencer in forum New Tools
    Last Post: 07-18-2007, 06:05 PM
  5. E. C. Atkins & Co. Indianapolis???
    Last Post: 12-31-2006, 06:10 AM
