Results 1 to 10 of 14
Thread: Ironwood bowl w/inlay
    Hey all, For your viewing pleasure; A bowl I made recently. I designed it as a change/carkeys/wallet type bowl with a smooth round curve on the inside for easily getting things out like,..well..a change bowl. Inlay is 1/2" squares of malachite and abalone. This piece took me quite a while. The diameter is 10.5" and about 3.5" tall. Thanks for looking, Barry
    Attached Thumbnails Attached Thumbnails abalone1.jpg   abalone2.jpg   abalone3.jpg
    Jul 2007
    DSM, IA
    5,719
    Well done Barry How did you attach the inlay? Epoxy? Great finish as well.
    My Website
    Goodland, Kansas
    4,834
    The bowl is a beauty Barry. The inlay really sets it off. Did you do any finish sanding or anything? Or was in once the inlay was in it was done? Did you use epoxy?
    Bernie W.
    1,289
    I am guilty of looking at the pictures before I read the post.
    The idea I had for using your bowl was exactly what you made it for.
    Well done Barry
    DT
    Red Deer, Alberta, Canada
    618
    Gorgeous, Barry, just gorgeous!!!
    Los Angeles, CA
    2,667
    Nice grain on the wood. Inlay makes it prettier.
    11,825
    Well done. The colors go well with that wood.
    30,002
    Beautiful work, Barry. I like everything about it.
    Thanks Guys,
    Actually, I sanded a lot after inlay (on the inlay area, that is) Starting with about 80 grit and working up to 600. Malachite is pretty soft so it's sandable, and of course abalone is sandable, just smells like the dentist is drilling your teeth. The finish is Johnsons paste wax. Yea, I set the inlay with epoxy. I put a few drops of walnut stain in it to darken it up, doesnt seem to effect the epoxy. I rough cut the inlay material into 1/2 strips with a tile wet saw. Then cut to squares with a dremel and a diamond disc, then sanded to final size/thickness on a belt sander with silicon carabide paper.
    Goodland, Kansas
    4,834
    Thanks Barry. I was wondering if it was the same as some of the stuff you can turn down and then sand. Appreciate it.
    Bernie W.
  1. desert ironwood
    Last Post: 04-04-2012, 12:58 AM
  2. Desert Ironwood SHF
    By Barry Richardson in forum Lathe Project Showcase
    Last Post: 01-10-2010, 05:06 PM
  3. First inlay bowl
    Last Post: 05-07-2009, 02:12 AM
  4. Desert Ironwood Pen
    Last Post: 02-29-2008, 09:48 AM
  5. Desert Ironwood
    By Barry Richardson in forum Old Ads
    Last Post: 02-09-2008, 01:54 AM
