Results 1 to 10 of 14
Thread: Different kind of nightstand...
    London, Ontario
    3,383
    Way back when I got married, my dad very nicely made a pair of nightstands for my wife and I. They have served us well for years. They are of a boxy cabinet type design, about 17x17x26"h.
    Unfortunately, our present house has the heating register in the floor right beside the headboard of the bed. Kind of a dumb location, IMHO, but what can you do? For years I've tried moving the nightstand to different locations. It has half-straddled it at times, which restricts heat flow, and it has been moved forward at other times, which places the nightstand too far forward, and leaves a weird gap at the back.
    Today it was a snow day for our family, so I thought I'd do something different and sit down and doodle on this design.
    There are two main ideas I started with. First, I was aiming more for an open table type of design. I want it fairly open, so that I can place it over the heating register and have it not obstruct the flow so much.
    Secondly, and more unique, I got the idea of building on a small pedestal to hold my clock up high above the table top. I've had the clock up hight for a while, and I kind of like it up there, and it also leaves the table more open.
    So this is what I've come up with so far, and I put it out here for comments, suggestions and so on.
    And here it is more or less in position.
ID:	17403 Click image for larger version.
    (Sorry, the *skp file is currently 440k, so I couldn't upload it. Dave probably could, but I can't... )
    I curved the front of the clock pedestal, but I haven't curved the front of the nightstand itself. I could be convinced otherwise. I haven't even given much thought to wood species, I just put in the colours right now for reference. (and I do like how cherry and maple go together)
    Heres a few more angles, to show the curved front, and the edge treatment.
ID:	17405 Click image for larger version.
    And now I'll probably sit on it for a while and ponder some more.
    9,077
    That looks like a pretty cool idea. You would have to be sure your alarm clocks in the future would fit as well(?) or buy a couple spares ;-)
    SE Minnesota
    2,526
    Art, I like it. So is the shelf for the alarm clock a sort of catapult thing that launches the clock across the room and out a window?
    If you want to send the SKP to me, I'll see if I can make it postable.
    TTFN
    dave
    London, Ontario
    3,383
    I might actually doodle another where the "clock shelf" extends across the whole width, just to see if I like that better.
    Glenn you've got a good point. The shelf is currently 9" wide by 4-6" deep (depending on the curve). That should handle most bedside clocks out there. BUT if I were to ever want a clock radio I might be stuck. (The clock radio has always been on my wife's side of the bed, so I didn't even think about it.) And yes, we both need clocks on each side of the bed. Not up for discussion.
    London, Ontario
    3,383
    Quote Originally Posted by Dave Richards View Post
    I've never had an issue with alarms. But then, this pedestal does nicely lift it up out of "swing arm over and bash the night table" space.
    SE Minnesota
    2,526
    A while back I heard about an alarm clock that was sort of an E-Z-Bale oven with a timer. You put a piece of bacon in it and at the set time, the clock would cook the bacon so you could awaken to that nice aroma. I think that could be nice for awhile.
    I got your file down to 193 Kb (better than a 50% reduction) which zips to a loadable size. Sorry but part of what I had to do was eliminate a couple of materials. There were also a bunch of unused materials that I gor rid of as well as a large quantity of unneeded lines and faces.
    Attached Files Attached Files
    San Antonio, Texas
    765
    I like it too, Art. Who says thinkin' outside the box ain't worth it?
    London, Ontario
    3,383
    Someone pointed out to me that a lamp would possibly not work on a table like this. And I think they're probably right. However, I have wall-mounted lamps beside my bed, so it isn't a concern. Just thought I'd mention that here.
    London, Ontario
    3,383
    poking some more...
    My wife thought a larger 'clock perch' might be more versatile, so I've poked some more at the design. I dropped the curved front also, as I thought it looked more out of place on the larger shelf.
    Here it is with one post:
ID:	17567Click image for larger version.
ID:	17568Click image for larger version.
    Here it is with two skinnier posts:
ID:	17570Click image for larger version.
ID:	17571Click image for larger version.
    Comments? Suggestions? I think that two supports works better with a larger shelf.
    I've thought about curving them a bit, but that doesn't seem in keeping with the tall/shaker lines of the bottom part of the stand.
    Cool idea, Art. I think I prefer the "two post" version.
  1. Nightstand and Changing Station .. delivered
    By Robert Horky in forum Flatwork Project Showcase
    Last Post: 02-15-2015, 09:24 PM
  2. Platform Bed with Nightstand
    By Bill Arnold in forum Flatwork Project Showcase
    Last Post: 04-14-2012, 06:13 PM
  3. Double Decker Nightstand...
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 02-22-2011, 03:16 PM
  4. G&G Influenced Nightstand - SU
    By glenn bradley in forum Designs, Plans and Sketches
    Last Post: 11-09-2007, 02:56 AM
  5. Finally FInished a Nightstand
    By Jesse Cloud in forum Flatwork Project Showcase
    Last Post: 12-09-2006, 02:04 PM
