Results 1 to 7 of 7
Thread: HVAC Question
    Herndon VA
    180
    HVAC Question
    OK this will probably be a dumb question, but here goes......
    I have a 2 zone HVAC system. One of the outside heat pump units runs pretty cold. So cold that after today's rain, the top has frozen chunks of ice around the fan shroud. The second unit that sits right next to it and is also a Carrier, is perfectly fine. The one with ice controls the main level of the house and tends to run longer.
    Is this normal?
    13,443
    I'm not an expert, but it sounds like it is low on freon, which will usually cause it to freeze over. What is the outside temperature? I know mine will switch to gas heat when it gets below 35 outside.
    Herndon VA
    180
    It is in the upper 30's. Both units are only 4 years old. I was told by the installer (friend of the family) that annual service was not required until about 5 years old. I guess it's time...
    13,443
    Have you washed the coils on them lately? I've got a neighbor with a cottonwood tree and have to wash the cotton out mine several times a season or it will clog up the coils. Just need to take a hose outside with a sprayer and wash them down top to bottom on each side. Might flip off the breaker to them first. But could be the problem, but still sounds a bit like low freon.
    Trinity County - 160 miles north of San Francisco. Redwood forest.
    159
    When we built our new home in the mountains of Northern California I selected a heat pump. Having studied about heating/ac for our old home (boiler and radiant panels in 4 zones), I knew enough to choose the latest technology known as 2-stage heat pumps. I'd heard that older versions can't produce heat at much less than mid-30s temps.
    One recent night, the pump was operating in 17 degree weather w/o the heat strips taking over. the 2-stage device is supposed to save about 40% on both heating and cooling. I bring this up because, if you have the option to replace the pump unit, get a 2-stage.
    Gary Curtis
    Trinity County Calif
    Herndon VA
    180
    Well after making the cardinal man-sin.... I consulted the manual!
    It says the ice build up on the unit is normal in colder temps. Either way I guess I'll start getting an annual service.
    The Heart of Dixie
    4,268
    Everyone has an opinion but after what I have seen as a Home Inspector I suggest annual service to my clients. Cleaning the coils is the biggest part of that too. As the coils get dirty, the efficiency of the unit drops. It will still cool and heat the house, just costs you more money to operate it.
    My HVAC buddy tells me that the minimum temperature difference between Return air and Supply air should be 12 degrees. At that point he says your well past the point your should have serviced the unit. It's still working but it's costing you more to operate it. I would say well over 50% of the units I check are at the 12 or 13 degrees difference.
    Where you live and what is around you will have an effect on how fast your coils clog up too. I just have him come out each spring and take care of mine.
    Custom built boats and Kits
  1. Any HVAC experts?
    Last Post: 06-02-2012, 01:35 PM
  2. question for those HVAC guru's out there.
    Last Post: 01-09-2011, 09:47 PM
  3. anyone do hvac?
    By doug frazier in forum Off Topic Discussion
    Last Post: 04-26-2009, 08:19 PM
  4. Any Experience with Ruud HVAC Systems?
    Last Post: 09-07-2007, 02:53 AM
  5. HVAC folks? Furnace won't kick in - thermostat clicks?
    By Art Mulder in forum Off Topic Discussion
    Last Post: 12-09-2006, 12:13 PM
