Results 1 to 5 of 5
Thread: Digi-Router
    Albuquerque, New Mexico
    1,099
    Digi-Router
    Anyone have the Digi-Router Retrofit on their JessEM MAST-R-LIFT?
    Do you like it? Their website says “Accurate to 0.010 inches (resolution to 0.001 inches, 0.01mm)” Can you accurately make .002 movements with it by using the digital display?
    I’m thinking about getting one for my Bench Dog lift but the “accurate to .010” has me a little confused….
    friend...if you have one."
    one."
    Orem, Utah
    935
    It sounds like the "significant digit" stuff they taught us in Science class. We always had to drop the last measured digit, because it was read "between the lines" on the ruler or the graduated beaker or whatever.
    Gee, that was a long time ago....
    Anyway, sounds like the device is more "precise" than it is "accurate". It would be tempting to trust a reported delta of .002, but I can't say whether that's a sound move or not.
    1,099
    I sent digi-kit.com an email asking the same question.
    one."
    Sep 2007
    Shorewood, WI
    97
    Accurate to 0.01" means that if you set it to a given setting, it should be within 0.01" of that distance. Resolution to 0.001" means that you can change the setting by that amount and see the difference. One is an absolute (accuracy) and the other is relative (resolution or precision) to where you happen to be.
    As a practical matter, it means that if you want to cut to 0.01" accuracy, you just set it digitally. If you need 0.001" accuracy, you make a test cut, measure how much it's off, and then change the setting digitally to get what you want.
    It sounds good to me.
    1,099
    So Alan, you’re saying that if I zero out and then using the digital readout raise the cutter exactly 1.000 (1”) it could be anywhere from .990 to 1.010?
    one."
  1. Router table router recommendations - What are your experiences?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 11-11-2012, 04:27 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  3. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
  4. Wixey digi read out for Planer and Groz bench plane
    By Jack Lemley in forum New Tools
    Last Post: 01-21-2008, 06:06 AM
  5. ? for you digi photog gurus
    Last Post: 07-19-2007, 08:23 PM
