Results 1 to 3 of 3
Thread: #3 infill plane . . .
    El Paso, TX
    146
    Pondering the stamped steel frog of this mutt #3 I'm think'n to myself " I wonder if we could use it as a base for a really nice infill type plane ? " . Might be a cool project. I went a-surf'n on the web but haven't found any descriptions of doing this, far less pics or plans. Only anecdotal acounts. Anyone ever tried it ?
    I would think it would be a tough project. The heart of the plane...and the most critical part is indeed the sole of the plane and then the frog...in that order. If you have a Mutt plane and the frog is questionable, even adding a beautiful infilled wood would just mean you have a beautiful, but crappy performing hand plane.
    Granted if you were real creative, you could also modify the sole and stiffen the frog with more iron through careful welding, some surface grinding and other machinists type tricks, but...if you are going to do that, then why not just start from scratch and make a plane?
    In some ways Paul Hubbman and I did what you were saying with his 1909 Stanley #140. I was working at Lie Nielsen at the time and through machining and rebuilding made a lack-luster Stanley #140 into a fairly respectable handplane. It was never made for some of the modifications we made on it, so it was not perfect, but there is no doubt what you are saying can be done. In fact we did it with Paul's plane...but to be honest with you, a Lie Nielsen #140 right out of the box would perform as equally as well and be a lot less hassle to get.
    Would I do it again? Maybe. It was a fun project and I have a clear conscientious as I know Paul's son is going to inherit a one of a kind handplane. A hand plane with history and a story, and you just cannot buy that.
    You can read about the entire rebuild of that plane here:
    http://www.railroadmachinist.com/Wood-Stanley.html
    Perth, Australia
    42
    Hi Steve
    This is my first post here - may as well come in with a flourish!
    The idea of using a #3 as the basis of an infill is perfectly sound. I have built two such infills, one a bevel up design based on a #3 (below) and another, a bevel down design, based on a #4.
    I love this little smoother. It was cut down to just 7 1/2" and has a very fine mouth.
    Go here for a full write up:
    http://www.wkfinetools.com/contrib/d...ootInfill1.asp
    Regards from Perth
    Derek
  1. It's a bird! It's a plane! No, really, it's a plane!
    By Roger Tulk in forum Handtool Project Showcase
    Last Post: 05-07-2012, 12:22 AM
  2. Plane gloat - rabbet plane
    Last Post: 03-21-2012, 09:08 PM
  3. My first plane
    By Chris Hatfield in forum New Tools
    Last Post: 03-14-2011, 09:46 PM
  4. Poor Man's Infill Plane
    By Jim DeLaney in forum Neander Woodworking Q&A
    Last Post: 07-26-2010, 11:11 AM
  5. Flush Plane / Flat Chisel Plane
    By Richard Line in forum Neander Tool Questions and Show & Tell
    Last Post: 10-06-2009, 09:12 AM
