Results 1 to 10 of 13
Thread: Started 3 more kids rockers in walnut
    Ridgetown, Ontario, Canada
    723
    Spent several hours in the shop today making parts. Back gets sore cranking the handle on the copy lathe ruffing out legs, etc. It was mentioned by another turner to turn the pin on the arm rest on the lathe. Sure beats sanding it round! I also tried making dowels on the copy lathe. 2 passes and the 7/8" dowel is done. Still have lots of work ahead detailing and sanding the ruffed out parts on the lathe.
    hobby woodworking since 1972
    Floydada, Tx
    1,941
    Looking good so far. Keep us updated as you go.
    Central Illinois
    936
    That Walnut is Fantastic! Can't wait to see the rockers finished. I'll need to be trying to make one in the next couple years for the WORLDS MOST BEAUTIFUL Granddaughter!
    OK.................... I AM prejudice! No offence intended to all the other grandparents out there.
    Bruce
    723
    a few more parts made and did a dry fit to see how it looks. It was suggested that I change the design to make it more appealing in the seat support area so I came up with a dowel / seat support in one. Now I find that the seat slats need to be tapered on each side as the rear is 2.5" smaller than the front.
    15,808
    Couple of things I'd like to say here......
    Bryan, you sir, do nice work
    the second thing is that with the nice work you do, it is still nice to see that your workshop gets into that "Work In MESSY Progress" stage that my workshop gets into
    I've got the making a mess part down pat, now I need two work on putting out the quality product part
    Thanks for sharing, can't wait to see these one!v
    723
    fridays progress
    this afternoon I made up the backrest ( mortise & tenon the slats to the top and bottom backrest ) and once the glue dried, marked the mortise locations on the rear legs to accept the completed backrest. After supper I got back to the shop and I chopped the mortises, and glued up the back of the rocker.
    You sure don't drag your feet when you get working on something, huh? Looking good so far, Bryan.
    723
    saturday's work
    Finished the glue up. Made up the tapered seat slats and screwed them on from underneath so no holes to plug. Last thing to make are two finials for the back legs. Then sand and finish. I am going to try using min wax's natural stain , then sanding sealer and a couple of coats of gloss lacquer.Click image for larger version.
    Bryan, the chair looks great! It has a really nice aesthetic to it - very inviting. I think any child would easily gravitate to it and claim it as theirs!
    Wes
    723
    Sundays work on chair #1
    Today I hand turned a finial . I then mounted the Vega copier on the lathe and made a 1/2 dozen quick copies. The finial being 4" long, only took a few minutes to produce one. Finished the day off by wiping a coat of oil on the rocker and removing any glue smears I missed. Tomorrow I will start spraying sanding sealer. The oil brought out the chocolate color, but is fading somewhat as it dries. Click image for larger version.
  1. One of My Kids
    Last Post: 08-06-2010, 01:36 PM
  2. Take a look Kids will always be kids
    Last Post: 05-07-2010, 12:47 AM
  3. Please Help the Kids
    By jim crockett in forum Off Topic Discussion
    Last Post: 04-30-2010, 03:23 AM
  4. toy for kids (and me)
    By Paul Hubbman in forum Flatwork Project Showcase
    Last Post: 01-23-2009, 07:49 PM
  5. sad day for old rockers...
    By tod evans in forum Off Topic Discussion
    Last Post: 09-17-2008, 09:48 AM
