Results 1 to 10 of 11
Thread: Sharpening Question!!!!
    Red Deer, Alberta, Canada
    618
    I just got my Vari-Grind jig from Oneway this morning and am very pleased with it.
    I've used it on my 3/8" Spindle Gouge and sharpened it at about 30 degrees. Now I'd like to sharpen my 3/8" Bowl Gouge. I have yet to do any serious bowl turning but would like to get it ready. What degree of grind do you bowl turners suggest I sharpen it at? I'm sure it shouldn't be the same as the Spindle Gouge but have no idea what the proper angle should be.
    Is there a consensus as to the proper angle or does each turner just do what he feels is the right thing for him/her?
    Thanks!!
    30,014
    Gord, I don't know what actual angles I use. I just try to match the way it came from the factory, and if I don't like it that way, I'll experiment in both directions. No idea what that the angles would measure. Hopefuly there are others here who can offer more finite advice.
    Drums, PA
    292
    Ditto what Vaughn said.
    Also, I sharpen my spindle gouges and bowl gouges the same.
    Just one setup to think about.
    Jan 2008
    Stow, OH
    151
    There is no definitely answer to your question.
    How many GB you have? What shape of bowl do you use it for (deep or shallow)? Which style you want to turn?
    If you follow Stuart Batty style of turning, he suggests 40 nose angle. With that sharp angle, it is less effort to slice through wood. But it limits the depth of the bowl you can hollow and still riding on the bevel. It would require a second BG of blunt angle for the bottom of not so shallow bowl.
    His style of grinding doesn't do well with the jig.
    YouTube - Tool Design and Grinding with Mike Mahoney
    Another is the popular Ellsworth type of grind. It is 60 ~ 65 nose angle. This is a suppose do it all kind of grind. Just like the Swiss Army knife, it is not the best knife or screw driver.
    Sharpening.pdf (application/pdf Object)
    Of course, there are a lot in between and completely different grind as well, like the traditional grind.
    IMO, the best grind does not exist, we gain some lose some. If whatever grind works for you, keep it.
    Gordon
    Los Angeles, CA
    2,668
    It depends on the type of turning that you intend to do. Here are some links that you might benefit from:
    http://www.sdwt.org/forms/Grind20061104.pdf
    http://www.woodcentral.com/newforum/grinds.shtml
    http://www.woodturningdesign.com/askdale/14/14.shtml
    Inside the Beltway
    2,666
    30 degrees? I've always heard 60, like here:
    http://www.newwoodworker.com/reviews/srbyfngnlrvu.html
    But I guess it depends on how you measure, or rather which side you're looking from...
    Speaking of 'it all depends', try this site:
    Want to get more confused? Try this:
    http://books.google.com/books?id=vh3...d-nHI3cBYbSQeA
    Hope this helps,
    Bill
    Inside the Beltway
    2,666
    Geez, Mohammad, you beat me to it by four minutes! Takes me longer than that just to type!
    Bill
    618
    Thanks for the replies, guys!
    I'll check out some of these links. I appreciate the help.
    Oct 2007
    Schenectady, NY
    912
    Oneway Website
    Gord,
    Oneway has a series of videos on their website on how to use their sharpening system. Take a look and see if it can help.
    http://www.oneway.ca/multi-media/index.htm
    I found them very informative.
    It also depends on how you are measuring your angle. Are you describing the angle formed by the long axis of the gouge and the bevel ? If you are the 30 deg. is good for a spindle gouge. As has been said already, about 40 deg. is good for a bowl gouge when measured the same way. More metal under the cutting edge for better strength.
    Don Orr
    Woodturners make the World go ROUND
    618
    Thanks Don, I'll check that out.
  1. Question about sharpening jigs...
    By Roger Tulk in forum Turning Tool Questions and Show & Tell
    Last Post: 12-01-2015, 02:49 PM
  2. Sharpening question
    By Tom Niemi in forum Neander Woodworking Q&A
    Last Post: 09-25-2011, 02:53 AM
  3. grinder and sharpening jig question
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 09-06-2009, 04:44 PM
  4. Sharpening Question
    Last Post: 06-26-2009, 06:20 PM
  5. Sharpening question
    By Mike Henderson in forum General Woodturning Q&A
    Last Post: 05-12-2008, 01:17 PM
