Results 1 to 10 of 10
Thread: Exploded Drawing
    Jan 2008
    Jay, Maine
    120
    Exploded Drawing
    After drawing an object in SU, is there a way to explode it to show dadoes, grooves, mortise & tenons, etc.?
    Second question, if I draw an object with a mortise and tenon, set the part in place with the tenon inserted, then later want to work on the piece away from the whole object, I find that I often "draw" the inside of the joint across the screen. Obviously I am doing something wrong here but haven't been able to figger out what.
    Here is a doll bunkbed design that I am working on. Questions, comments, sarcastic remarks are appropriate.
    Jim
    SE Minnesota
    2,526
    The simple answer is, "components." You need to be making components to keep the individual parts of your model discreet. If you make components of each piece of wood, you'll be able to do everything you want. I've written here many times about using components so I won't do it now. I would suggest that you read through the forum.
    Cedar Park, TX
    320
    Hey Jim, Welcome to the forum. Like Dave said, make each piece into a component and that will make a whole lot of stuff much easier. As to exploding drawings into parts, there is not an automated way to do that, but if the parts are component, you can simply drag individual parts away from others and drop them where you want them.
    To work on a particular component without other pieces getting in the way, you can go to the View Menu, Component Edit, and click hide rest of model. When you double click to edit a component, the rest of the model will disappear and only your component will be visible. You simply toggle that setting on and off as needed.
    There are a ton of sites out there with tutorials on SketchUp. Dave has an excellent one with a bunch of tutorials, but I don't have the link here. maybe he'll add that to his signature file if we ask him nicely. There's also a forum with lots of really helpful folks here. http://www.sketchucation.com/forums/scf/index.php In the Newbies section there, there's a post with a bunch of links to other stuff and the tutorials sections has some great stuff, too.
    Jerry
    Geneseo, Illinois
    61
    Anyone
    What happened to the Click & Build Blog at the Fine Woodworking wb site?
    there is a wealth of help there thanks to dave.
    SE Minnesota
    2,526
    Les,
    It's still there. Click on the link in my signature.
    Cedar Park, TX
    320
    Thanks for adding the link to your sig, Dave. Makes finding that a lot easier. Great stuff, there BTW.
    Jerry
    London, Ontario
    3,383
    Quote Originally Posted by Jerry Palmer View Post
    Are you kidding, Jerry?
    If you enter the three words "Design Click Build" into Google, then Dave's blog over on Taunton is the FIRST link returned. It's hard to get much easier than that!
    Cedar Park, TX
    320
    Yeah, easy if you remember what the site is called.
    What's surprising to me is that Taunton lets me in without giving them money to be a member.
    Jerry
    SE Minnesota
    2,526
    Our blog is the loss leader to get you in the door.
    Cedar Park, TX
    320
    Sshhh. Don't tell anyone, but from what I've seen over there on a few occassions, the SU Blog is the best thing there.
    Jerry
  1. Drawing a Waterwheel?
    Last Post: 01-26-2013, 03:48 PM
  2. exploded view 0f log
    By Paul Gallian in forum Off Topic Discussion
    Last Post: 01-25-2013, 04:34 AM
  3. drawing ogees
    By Carol Reed in forum Designs, Plans and Sketches
    Last Post: 02-19-2010, 11:06 PM
  4. New Device for Drawing
    Last Post: 08-23-2008, 05:28 PM
  5. Sketchup drawing for island
    By Donnie Cherry in forum Flatwork Project Showcase
    Last Post: 05-19-2007, 01:49 AM
