Results 1 to 10 of 15
Thread: Can you put a flat panel here?
    Houston, Texas
    2,323
    With the change up to HD TV and the flat panels many folks are needing to go for a re-fit in their existing TV spaces.
    Here is the situation.
Name:	before and during tearout (16).jpg
    The TV selected was wider than the space allotted so with the TV dimensions in hand I drew up 3 options I thought would work, considering he wanted the center channel speaker above the TV and his components to show, my design was to be within the guidelines.
    Can you see the differences in the drawings?
    Shaz
    Please join me. Register now.
    Shaz
    Here is how
    Southern Louisiana
    947
    shaz, are you rebuilding the entire unit or just redoing the upper section?
    i think he should be happy with one of those 3
    chris
    Tokiwadai, Japan
    2,882
    Nice..I like #2, but think the owner went with # 1... No?
    Charlotte, NC
    1,487
    Gotta agree with Greg. The second one seems more pleasing to me, since the speaker mimics the shape of the TV.
    I prefer the second drawing. It feels less busy and does not distract from the TV.
    30,014
    Add another vote for #2. And Shaz, you're getting good at the Sketchup stuff, Those drawings look almost hand-drawn.
    London, Ontario
    3,383
    I LIke #2 also, but is #1 the only one where there is room for components, and that would be above the TV ??
    At least, if you're taking up the same space as the original, and if the TV is wider, then it seems to me that there is NOT room for components on either side of the TV. So they either need to be above or below the TV, and #1 is the only one where I see shelving room.
    ...art
    Houston, Texas
    2,323
    Hi Chris ,
    Just doing the upper unit, well a little bit below, behind the center 2 doors.
    Hi Greg ,
    You will get to decide, by the photo, Good guess!
    Hi Ed ,
    That it does, I had not picked up on that! Good eye!
    Hi Glenn ,
    Appreciate your input.
    I agree that it looks less busy and he does like art work. Hmmm, Maybe some long slender sculptures? Number 3 has the same look if you take out the adjustable shelves.
    Hi Vaughn ,
    I didn't think anyone would notice except maybe, DR Richards.
    Actually it is a hand drawn divide and conquer plan. I draw all the fixed unchangable marks on a piece of paper, copy that, then fill in the blanks on the different copies with different ideas. Kinda like sketch up?
    Hi Art ,
    Very in intuitive, actually #3 can also have those shelves added, they have not been drawn in.
    This is the reasoning power in you I respect so much. That same wisdom that allows you to hold on to the tip of a rocket! with no fear of being carried into space!
    Had you known shelving could have been added there I know you would have deduced that #3 was also an option.
    ...art
    The selection he made was #3 due to the fixed horizontal line above the TV, rather than the equally divided spaces of the sides in #1.
    He opted for #3 over #2 because of the opportunity to situate several conponents left and right of the speaker, with the speaker upright.
Name:	Dr. Hoyle drawing accepted (451 x 600).jpg
    Next, the tear out.
    Shaz
    Shaz
    Here is how
    Topeka KS
    118
    to me it looks like all of those components will be hard to fit in the available spaces
    do you have a drawing with original dimensions? it appears the original component shelves are as wide as the cabinet doors in the lower portion so to me it would seem the shelves would need to stay that width to fit the components. it looks like as many as 13 individual components at different height shelve spacing. to my eyes none of your drawings seem to address this!
    Houston, Texas
    2,323
    Quote Originally Posted by Mike Gager View Post
    to me it looks like all of those components will be hard to fit in the available spaces ( Hi Mike , You are absolutely right, and the client knew that going into this re-fit. He was told that the components would have to go down below behind the doors...S )
    Most components have a maximum of 17 1/4", som of the newer higher powered receivers and some of the storage units (mega storage for dvd) are up at about 18". This figured, I determined that there was room for several components to fit within view above the TV beside the speakers.
    He lost some of the components in the refit due to obsolescence.
    As far as the space below, behind the doors the outside units had room back behind the stiles where components would fit and the center 2 doors had merely a common frontal stile for the doors with no divider, thus that room behind the center stile was also made available.
    Good point and good question.
    As far as my drawings addressing sizes per say, I usually know going in that what I draw is a workable thing (having taken the measurements into account as my determining factors for size) thus the measurements do seem to take a back seat. They are however at the very core of the plan.
    Shaz
    Shaz
    Here is how
  1. Another panel
    Last Post: 02-26-2011, 09:39 PM
  2. OK. How flat does it have to be?
    Last Post: 09-06-2010, 02:58 PM
  3. flat panel cabinet door w/ glass question
    Last Post: 06-23-2010, 04:32 PM
  4. how flat is flat enough?
    By Mark Kosmowski in forum Neander Woodworking Q&A
    Last Post: 05-23-2010, 03:19 PM
  5. What is the use of a panel saw?
    Last Post: 05-17-2009, 07:42 PM
