Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Show me your Dust Collection Set_up
    I am going to hook up my Delta 1200 cfm DC with PVC Piping and wanted to get an idea of what I should do.Post pics if you got em.
    Marc
    Welcome aboard, Marc. I won't be of much help for your questions. My DC setup consists of a 20' long piece of 4" flex hose that I move from one machine to the other. Everything is mobile, so at this point it doesn't make sense for me to put in permanent piping. My previous setup had a 4" flex main line, with branches out to several of the main tools. I think I spent as much time opening and closing blast gates as I do simply moving the hose now. (I use a quick disconnect.)
    As you probably know, your PVC piping will have less drag than my flex hose. Someday I hope to have a bigger shop where I can set up a more permanent DC solution.
    thx vaughn,
    I just wanted to get some ideas through pics.I know that woodcraft sell some adapters to connect the 4 " Pvc pipe that you get at home depot to the Flex pipe and Blast Gates.I have seen people use silicon caulk for the blast gatesw and was wondering why.Is it needed?Or is it only because they are not using the special adapters.
    Marc
    Hey Marc...how is this for dust collection?
    I am just joking with you. I don't have pics of my set-up and I doubt you would want to see it anyway. In any case this is a picture of a 1790's sawmill near me. They used the table to flap the sawdust into the barrels. Quite labor intensive, but ingenious too.
    Welcome to the forum though, and I hope you get better responses then my smart-alec answer.
    El Paso, TX
    146
    KISS ! . . .
    Simple, simple, simple ! I kept all my PVC same size as blast gates and hoses. Bought the Craftsman kit with hose & gates. Think I had to buy a couple extra gates though. Both sides of the shop go to the corner, meet in a tee then into the vac " cabinet " ( if I may use the word ). I cut a vent from my " cabinet " to the outside for some reason. Vac plugs into an outlet inside my " cabinet ". Outlet is wired to a swtch at each station ( 4 ) individualy ties in to the outlet. NO three way switches ! That was VERY confusing to GI. The smartest thing someone advised to NOT do was to NOT seal anything ! Gates, fittings or hoses. No, no, no ! The PVC seals fine even with just a shop-vac by itself and, I promise you, you'll be takeing it apart to clear stopages at some point ! My simple cheap system is one of the best things I built into the shop. OH ! Install one more gate with just a hose at some point to suck off the bench top. Handy as all getout !
    Attached Thumbnails Attached Thumbnails dust1.JPG   dust2.JPG   dust3.JPG   dust4.JPG
    9,077
    Northern Ohio near Sandusky
    32
    Here's some of my ideas
    Dust collector over here
    Inlet on other side of wall
    6" home made blaste gate going to 6x6x4" Y one to table saw one to jointer
    Radial Arm Saw port
    Router fence hookup
    Bandsaw
    Planer...I just slip off connection from the band saw or table saw
    I recently added a port and blast gate for a Ridgid sander to the left of the RAS table but haven't taken a pic yet.
    No silicone on connections.......no leaks
    Overall view
    JEFF
    If it don't fit get a bigger hammer
    The Heart of Dixie
    4,268
    Here is mine
    Custom built boats and Kits
    Ha Ha ,I always get that one.
    Here is mine
    The Heart of Dixie
    4,268
    Old joke, I know. But it's true. Well I use a shovel
  1. i-Box Dust Collection
    Last Post: 10-31-2013, 03:40 AM
  2. Dust Collection
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 08-13-2011, 08:19 PM
  3. dust collection
    By gary doby in forum General Woodturning Q&A
    Last Post: 04-25-2009, 08:54 PM
  4. Dust collection?
    Last Post: 01-21-2009, 11:46 PM
  5. dust collection
    By J W Seals in forum General Woodworking Q&A
    Last Post: 10-31-2008, 03:12 PM
