Results 1 to 10 of 10
Thread: Help desperately needed NOT LMAO
    Rhode Island
    800
    Unhappy Help desperately needed NOT LMAO
    well this is the vase I'm making for LOML for her work desk. As you can see I got the square base ready to be turned into a domed shape so I can insert it into the bottom.
    Click pic 2 times for full size.
    Now in this pic (after you stop laughing) as you can see by my thumb I got a little over zealous with the forstner bit. My question is what advice can you give me to save this piece. I have more of the Bubinga as you can see in the first pic. > :-[ :'(
    Drums, PA
    292
    Hi Chuck
    Reverse chuck it with a jam chuck and and fit it with a plug.
    Quote Originally Posted by Ron Sardo View Post
    Hi Chuck
    Yep, then burn the pictures of the hole, as it NEVER happened
    Hole??? What hole???
    What happens on FWW stays on FWW. Right Stu?
    George
    Quote Originally Posted by George Conklin View Post
    You betcha George, we ain't telling no one
    Just glue another piece of wood to the bottom and keep going. Maybe even some contrasting wood.
    Chuck...nice dual orfice vase! Did you say you intend to turn a bubinga plug for that? Is this your first dual orfice segmented piece?
    Ken
    Either do what has already been suggested, or put a couple pieces of curved glass in it and call it a telescope!
    Been there done that, almost. I didn't go ALL the way through.
    Goodland, Kansas
    4,834
    Chuck I would use a jam chuck, part off the bottom and glue a new piece in place then turn to form and finish. I am not going to tell you been there, done that.
    Bernie W.
    2,784
    Can you counter bore another hole from the bottom with a larger forstner bit, then turn a plug to glue into it? That way the outside vase appearance wouldn't change, and you'd never see the plug in normal use. Also would use less of the Bubinga. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
  1. Prayers desperately needed...
    By John Pollman in forum Off Topic Discussion
    Last Post: 09-26-2013, 01:55 AM
  2. It Just Needed It....
    Last Post: 02-28-2012, 05:51 PM
  3. help needed
    By john e duck in forum Jigs and Fixtures
    Last Post: 05-30-2008, 04:53 AM
  4. Desperately looking for some feedback!!
    By Toni Ciuraneta in forum Designs, Plans and Sketches
    Last Post: 04-15-2008, 06:16 AM
  5. Definitely you must read this one (LMAO)
    By Chuck Beland in forum Off Topic Discussion
    Last Post: 10-07-2007, 04:23 PM
