Results 1 to 6 of 6
Thread: Good technique for cutting wedges
    Fredericksburg, VA
    161
    Howdy, All!! Last night, I modified the joinery design of a project I'm working on for my kids. I need to cut a number of small wedges for a wedged-tenon joint, and am looking for some guidance on an efficient, safe way to do this. The wedges dimensions will be roughly 1.5"L x .75"W, and about 3/16 thick at the top. Like I said....small.
    Any advice would be greatly appreciated!
    Regards,
    Keith
    "Listen, here's the thing. If you can't spot the sucker in the first half hour at the table, then you ARE the sucker. "
    San Antonio, Texas
    765
    Keith, when I need to make parts that small I always turn to a sled for my table saw. You can build a block and fence system that will work like a tapering jig to hold the pieces. Safest way I know.
    Cedar Park, TX
    320
    Sled is a good idea. Add some sort of method for clamping the stock to the sled for the table saw use. I'd be happier doing it on the bandsaw, myself and cleaning up the cuts on the beltsander.
    Jerry
    Keith I am forced to make small parts all the time for my custom wooden models. When it comes to cutting small parts I head to two machines, my bandsaw or my scrollsaw. That is because high powered blade spinning machines have enough airflow from the spinning blade to blow them almost anywhere.
    The bandsaw or scrollsaw does not have kickback, and allows you to really hold the part without fear of cutting off your fingers. I always make my parts long, then cut off the small from that just to be safe.
    If you don't mind doing stuff by hand, cutting them with a dovetail saw or miterbox gives you the ultimate control and safety.
    Fredericksburg, VA
    161
    Thanks, guys!!
    Travis, the scrollsaw is a great idea. I hadn't thought of doing it that way!
    I appreciate the help, Gents!
    - Keith
    Bob Wiggins is offline Former Member (by the member's request)
    140 miles west of tulsa
    125
    I'd be inclined to use my trusty old tablesaw. With an 8 or maybe 10 inch width of lumber cut the taper similar to this cutting board end. Then rip into strips the desired width followed by cutting each to length.
  1. Cutting plywood, good face up or down?
    By Jeff Bower in forum General Woodworking Q&A
    Last Post: 03-06-2014, 02:23 PM
  2. Planing technique
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 11-27-2012, 10:05 PM
  3. Anyone ever try this technique ?
    By Don Baer in forum General Woodturning Q&A
    Last Post: 06-21-2012, 09:45 PM
  4. Haven't had a good cutting board debate in a while...
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 08-13-2011, 12:00 AM
  5. would like more info on DNA technique
    By Ken Easley in forum General Woodturning Q&A
    Last Post: 08-06-2008, 03:09 PM
