Results 1 to 4 of 4
Thread: Extending Mortiser for use wiht xy vise
    Tampa
    281
    I've seen a couple of solutions to the problem of using an xy sliding vise due to it's higher profile on a mortiser.
    I bought the HF mortiser for 99 maybe a year ago and just recently got ahold of the 4 inch xy sliding vise.
    The height of the vise of course required the mortiser to be raised and the base be turned backwards but this makes the whole thing much deeper and the base would need ot be secured pretty well to what ever base you came up with.
    Well, one day I was looking at my 14" bandsaw and happen to glance at the riser block I got from Grizzly and it gavve me an idea.
    Here's what I came up with. It is solid and very very stable. It's made of 4" x 1/4 steel plates from Lowes cut to size and drilled as needed.
    http://tarimagica.com/jna/
    The hardest part was getting the drill holes where the verticle rods inset into a 11/16" recess. I madde the recess a smidgen larger and still I was about 1 mm off but was able to adjust it using a grinder. The inset holes I drilled in the top plate had to be exact in order for the verticle rods to fit into place.
    This set up has given me about 5" of extra space.
    I am hoping to test it out this weekend.
    Hope someone finds this usefull. (BTW, my welding seems to be getting better. )
    Constantine, MI
    7,891
    Very cool solution - thanks for posting this!
    We all die. The goal isn't to live forever; the goal is to create something that will. - Chuck Palahniuk
    www.wrworkshop.com
    Tampa
    281
    I made two modifications to the vice that I saw done somewhere on the net. I had to reverse the screw rod that slides the vice in the front to back direction because the turn handle is behind the vice. I drilled and tapped two holes at the front of the vice just below the jaw screw. then I removed the side to side screw rod cos its longer and put that one on the front so I could extend the jaw clamp farther. The short one I put on the side to side slide.
    30,017
    Great job, Julio. I wouldn't have thought of making the riser out of plate steel like that, but it makes great sense.
  1. That Ain't a Mortiser. This is a Mortiser
    By Dave Richards in forum General Woodworking Q&A
    Last Post: 05-15-2014, 12:33 PM
  2. jet mortiser
    Last Post: 02-28-2010, 12:47 AM
  3. Tail Vise VS Shoulder Vise
    By Rich Aldrich in forum General Woodworking Q&A
    Last Post: 10-30-2008, 12:44 AM
  4. Do you own a JET mortiser?
    By Jeff Horton in forum New Tools
    Last Post: 08-11-2008, 11:46 AM
  5. Extending cherry stock with MDF
    By Ken Close in forum General Woodworking Q&A
    Last Post: 11-21-2007, 08:26 PM
