Results 1 to 4 of 4
Thread: Table saw blade alignment - Lo-tech / Hi-tech
    Nov 2007
    Poland
    267
    Good day
    Well, it's almost spring and I started to "warm-up" the machines...well, table saw and router table...that's all my "machines".
    I don't have all this expensive equipment to align the blade to the miter slot so, I used a "Lo-tech" method just to bring the blade as parallel as I can, to the miter slot. I call it "Static alignment"
    In my opinion, all the "Hi-tech" (and Hi-price) instruments can be "super-duper" accurate but, I think that the blade itself "knows" better if it is aligned to the miter slot or not.
    I call this check, "Dynamic alignment"...I just clamp a strip to the sled (or the miter gauge) and cut...when the strip reaches the back teeth, I listen to the noise...
    If it's "cutting" noise, I know that I have to turn the blade clockwise.
    If I don't here any noise, I know that I have to turn the blade counter-clockwise.
    If I hear a "scratching" noise (I mean, the back teeth are just touching the strip) I know that the alignment is good.
    Later, I check the fence alignment to the miter slot (Static check), rip some thin board and listen to the noise of the back teeth (Dynamic check)....and, same as above...
    Actually, you can omit all the "Static test" and align the blade only by using the "Dynamic test"...especially if it's only minor correction, but the "Static test" will save some time and if you are lucky, the "Dynamic test" will prove good on the first time.
    Regards
    niki
    And here is the "Dynamic test"
    Listen to the noise of the back teeth
    Bring the rip fence close to the miter slot and check the distances at one end...
    ....And the other end
    Cut a test piece and listen to the back teeth noise...
    Nov 2007
    Poland
    267
    I do the same also on the long fence
    To check the squareness of the sled, I took a piece of thin board (floor panel)....
    And cut it to 4 pieces
    I alternate the pieces and checked them on a straight edge...any mistake will multiply itself...
    Niki
    Could you show us your modifications to the dial calipers. Looks interesting I think I see what you did but still would be interested in your description.
    Thanks
    Keith
    Nov 2007
    Poland
    267
    Hi Keith
    There are already too many pics on this post so, I'll post it on separate thread "Caliper modification"
    niki
  1. It's a Tech Challenge
    By Leo Voisine in forum Programming, Troubleshooting, and Q&A
    Last Post: 10-15-2014, 11:41 PM
  2. Keeping up as we all age...tech sector
    Last Post: 11-03-2011, 05:24 PM
  3. Answer from the woodcraft tech..
    By Paul Gallian in forum New Tools
    Last Post: 11-19-2009, 04:02 AM
  4. Need tech/sound help
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 05-07-2009, 02:32 AM
  5. Table saw - Lo-Tech blade adjustment
    Last Post: 02-03-2008, 10:10 PM
