Results 1 to 5 of 5
Thread: Help with Bosch 1615 EVS . . .
    Long Hill Township, NJ
    467
    Hello:
    12 or 13 years ago I bought a Bosch 1615 EVS plunge router. I can't find the owners manual in the house or on-line.
    The detail I'm looking for is the spindle RPM's at each variable speed.
    I'm looking to use it in a table with a lock miter bit and the bit is designed for XXXX RPM.
    Anyone help would be appreciated.
    Thanks in advance.
    Jim
    You're right...the manual doesn't appear to be online.
    I did find a reference on WoodCentral saying it has a speed range of 19,000 RPM down to 12,000 RPM. You could probably extrapolate the speeds between those two extremes and get a rough idea what the settings on the dial would translate to.
    Tokiwadai, Japan
    2,882
    Still looking for the manual....here's a parts breakdown if you don't have it.
    http://www.toolpartsdirect.com/cgi-b...h/1615EVS.661/
    Seems the 1615 was replaced with the 1619... Here's the 1619 manual for your ref:
    http://www.boschtools.com/Service/Pr...delNum=1619EVS
    467
    Thank you for all the replies.
    Thats the information I needed.
    Cheers
    Jim
    Sicamous (sic-a-moose) British Columbia Canada
    69
    Always gone by bit diameter. Like yourself lost the "chart" Big( panel rasing etc) slow. Just a little smaller (in diameter) a little faster, smaller then a little smaller faster, small (edging) fast. Works for me Don't get "hung up" on rpm, 1000 rpm isn't going to make much difference.
  1. Bosch Glide Saw
    By Jonathan Shively in forum General Woodworking Q&A
    Last Post: 09-13-2010, 02:09 PM
  2. Bosch Blades ?
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 08-06-2010, 10:20 PM
  3. Bosch New Slider
    By Steve Southwood in forum New Tools
    Last Post: 06-14-2010, 10:12 PM
  4. The Deal gets better On Bosch 12v
    By Rob Keeble in forum Hot Deals
    Last Post: 04-01-2010, 12:36 PM
  5. Bosch Colt and Bosch Jigsaw
    By Jim C Bradley in forum New Tools
    Last Post: 10-30-2007, 05:18 AM
