Results 1 to 10 of 18
Thread: Countertop Mod
    Charlotte, NC
    1,487
    Countertop Mod
    What would you use to cut a countertop? I have a drop-in stove that is being replaced with a range/oven unit and the counter will need to be cut for the install. My biggest concern is the backsplash. I can use a jigsaw to get close to teh backsplash, but then what? Here is a real rough sketch of what I have.
    4,992
    ed, if it`s a freestanding unit like you show (not mitered into another piece of countertop) it might be easier to remove the whole top and cut from the backside?.....if that`s not an option a sawsall with a fine tooth metal blade, or if you can find one locally a reverse tooth, cut close to your line and sand to fit with a beltsander.....tod
    Charlotte, NC
    1,487
    Thanks Todd,
    I haven't had a chance to look at the project yet, but I have had this question come up before and I have puzzled over how to do it. The recip is probably the best idea.
    By the way, where in the Ozarks are you? My folks live in Kimberling City.
    Ed
    Woodstock, GA
    178
    How a trim router using a template?
    Charlotte, NC
    1,487
    Quote Originally Posted by Ken Whitaker View Post
    Not sure how I'd design a jig to take a router from the flat countertop to teh vertical backsplash. That would probably leave the best finish, but I can't figure out how to make the turn.
    Steve Clardy Guest
    Jigsaw.
    TAPE your cut line. This helps with chipout.
    Dewalt also makes a reverse cut blade. It cuts down, not up.
    Backsplash. Hand saw or recep saw.
    If you can remove the whole thing, a skillsaw with wood guide clamped to it. Cut the backsplash first
    Charlotte, NC
    1,487
    Thanks Steve!
    I was sorry to read about the troubles you have been dealing with. Hope you're close to operational again.
    Hi Ed. First off, the range top manufacturer should have included the cut-out dimensions with the unit. Lacking those instructions, I would flip the top over and proceed to build a template that will fit around the underside of the unit. After having made the template, you have two choices. 1) double stick the template to the counter top and use a trim router to cut the hole. 2) Use the template to draw an outline of the hole. Then drill a hole at each corner and use your jig saw to cut the straight-line sides from hole to hole.
    When I install an Elway stainless sink last winter, I spent a lot of time making a template for the sink underside. One of my considerations, like you, was the spacing to the back splash. I cut the width of the back edge of the template such that when it was pushed up to the back splash, the cutout was positioned properly. I used option 2 above.
    The cutout doesn't need to be pretty, but it definitely needs to be the correct size.
    Steve Clardy Guest
    Quote Originally Posted by Ed Nelson View Post
    Thanks Steve!
    Thanks.
    Trusses are up
    Toronto, Ontario, CANADA
    2,332
    Except for one time, a jig saw has always gotten close enough to the backsplash. I have a plastic thingy that fits around the blade of my saw to prevent chipping and it works very well.
    That one time that I could not get close enough, I used hand saws -a drill then a keyhole saw to start the cut then a small crosscut saw for the bulk of the cut.
    Cheers, Frank
  1. Oak countertop finish; advice needed.
    By Tony Maio in forum Finishing School
    Last Post: 05-13-2013, 06:41 PM
  2. Replacing kitchen countertop
    By Tom Baugues in forum Carpentry and Construction
    Last Post: 09-30-2012, 10:40 PM
  3. The making of Jarrah Countertop
    By Tom Niemi in forum Flatwork Project Showcase
    Last Post: 07-11-2009, 01:34 PM
  4. Cutting Laminate Countertop ?
    By Ed Nelson in forum Carpentry and Construction
    Last Post: 12-22-2007, 11:36 PM
  5. Replies: 25
    Last Post: 01-30-2007, 11:17 PM
