Results 1 to 9 of 9
Thread: Walnut jewerly box
    Walnut jewerly box
    Let me know what you would do different.
    http://s166.photobucket.com/albums/u...on=tageditmany
    I would post the pics here on the forum so they could be saved for posterity. Link no workee.
    I'm not able to see the pics, Scott.
    13,452
    Scott,
    If you need to resize your pics for adding to the forum, I use Picture Tray (http://www.picturetray.com/). It's a single executable file to run it, so I put it on my desktop and launch it from there. Just drag/drop your pictures onto the left pane and new pics will be placed on your desktop. Upload the files and when you close Picture Tray it will cleanup the resized picture files (so if you want copies of the smaller files copy them somewhere before closing it).
    I did a printscreen of my settings that I use and attached it.
    13,452
    ok, looks like you can get to the pics here (http://s166.photobucket.com/albums/u120/snturner/Box/).
    Very nice. You do nice work. The wife must be very happy with it...and to finally get it.
    So, I still want to see some pics of the poster board technique for the felt.
    Thanks for finding the pics, Darren.
    Scott, that's a beautiful jewelry box. Very nicely done.
    Yes I screwed up the link. When you click on it there is a message that says no pictures selected, but if you scrol down they are there. So I am using Darren's suggestion and try this.
    http://i166.photobucket.com/albums/u...Box/open-1.jpg
    http://i166.photobucket.com/albums/u...x/closed-1.jpg
    Let's see how this works.
    11,833
    What I would do different is probably mess it up so it wouldn't be nearly as well done.
    BTW, I enjoyed your Vegas era pin-ups on the first incorrect link.
    Nope sorry it's not a plan. I seen this box on a retail web page and decided to make my own. I do most of my woodworking from my head. That also makes for a few do-overs during a project. The box is 11" high 15" wide and 9" deep.
    It's a lacquer finish. I had to put a lot of lacquer on and do a lot of sanding because I made the mistake of not using a grain filler first. That was lesson one.
    I used poster board wrapped in felt for the lining. I like the way the poster board adds thickness to the felt. I use a hot glue gun to glue it in place on the box. Sorry Darren no pics. I tired a cotton fabric on a previous box. It was too hard to keep straight. The ring pads in the top are from Rockler. The reason I buy the pads from them is because I also get the felt from them and they claim the material matches, and it does. I wish they had some ring pads that were round on the top instead of square. I think that would add a softer look.
    On the top lid, I routed a groove and glued a thin piece of popular in. I steamed, glued and clamped the popular in place. I was shooting for a jet black trim. It didn't work as you can see. Again I should have used some type of grain sealer before staining.
    On my next box I believe I will make of a trim section and spray it with a black lacquer.
    Thank you for all your comments and suggestions.
  1. Jewerly Box
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 12-01-2009, 01:19 PM
  2. A Little Bit of Walnut
    By Vaughn McMillan in forum General Woodworking Q&A
    Last Post: 05-17-2009, 08:55 AM
  3. Walnut HF
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 04-20-2009, 10:32 PM
  4. Walnut box...
    By Mike Stafford in forum Lathe Project Showcase
    Last Post: 09-13-2007, 07:54 AM
  5. Walnut box
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 07-23-2007, 02:48 PM
