Niki Avrahami
In Memoriam
- Poland
Good day
I made this table for different purpose but, I will not tell you which one because you will laugh on me.....
But, while working on it in the garage, I thought that I can use it also as an adjustable height table for the Drill press, table saw, router table and alike to support long boards so, I made a few modifications...
The base is two, same length frames, M&T, connected with bolts as an X...the top can be any plywood, melamine or whatever.
I did not have intention to post it but then I thought, maybe it will give somebody some ideas...
For garage use, I would make it from some 2" x 4" with a wider base, say, 30" for better lateral stability
Regards
niki
Regards
niki
